Hehe, point taken. I am unsure what kind of information would help you since PaperUI does all the configuration and, as mentioned before, the initial data load works just fine.
So here is the bridge configuration part from /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.Thing.json
"darksky:weather-api:DarkSkyAccount": {
"class": "org.eclipse.smarthome.core.thing.internal.BridgeImpl",
"value": {
"label": "Dark Sky Konto",
"channels": [],
"configuration": {
"properties": {
"apikey": "---redacted---",
"refreshInterval": 5,
"language": "de"
"properties": {},
"uid": {
"segments": [
"darksky",
"weather-api",
"DarkSkyAccount"
"thingTypeUID": {
"segments": [
"darksky",
"weather-api"
The weather info part starts as follows
"darksky:weather-and-forecast:weatherSTR": {
"class": "org.eclipse.smarthome.core.thing.internal.ThingImpl",
"value": {
"label": "Wetterinformationen",
"bridgeUID": {
"segments": [
"darksky",
"weather-api",
"DarkSkyAccount"
"channels": [
"acceptedItemType": "DateTime",
"kind": "STATE",
"uid": {
"segments": [
"darksky",
"weather-and-forecast",
"weatherSTR",
"current#time-stamp"
"channelTypeUID": {
"segments": [
"darksky",
"time-stamp"
"label": "Letzte Messung",
"description": "Zeigt den Zeitpunkt der letzten Messung an.",
and ends after a while with
"label": "Vorhergesagter Ozon-Wert",
"description": "Zeigt den vorhergesagten Ozon-Wert an.",
"configuration": {
"properties": {}
"properties": {},
"defaultTags": []
"configuration": {
"properties": {
"numberOfAlerts": 0,
"forecastDays": 1,
"location": "48.784354,9.181409",
"forecastHours": 12
"properties": {},
"uid": {
"segments": [
"darksky",
"weatherSTR"
"thingTypeUID": {
"segments": [
"darksky",
Pulling the last update into an item shows the date of the first data load (or restart of openHAB or the binding) but never updates.
DateTime weatherUpdate "last weather update [%1$td.%1$tm.%1$tY %1$tH:%1$tM:%1$tS]" <time> { channel="darksky:weather-and-forecast:weatherSTR:current#time-stamp" }
Any idea on that? Any additional information that I can provide?
Thanks!
