Dash Button Triggers Itself
Hi all, I setup some dash buttons in the greenhouse. Pretty simple use case. We water plants everyday, some days with nutrients, some days we do the floors. Wanted a way that worker bees could just press a button when they water etc. Dash button fit the bill.
I installed them just fine. Push the button and rule fires. Problem is, the dash button just keeps on triggering and adding to the count. I posted the rule below:
//daily tasks
var Number Floor_Spray
rule "Floor Spray Counter"
	Item Floor_Trigger received command ON
     Floor_Spray = Floor_Spray + 1
 logInfo("floor water counter", Floor_Spray.toString)
 Floor_Spray1.postUpdate(Floor_Spray)
rule "Dash Floor Spray Counter"
	Channel "amazondashbutton:dashbutton:78-e1-03-98-69-00:press" triggered
//Dash Timestamp for sparying the floor
rule "Dash Timestamp for spraying the floor"
	Channel "amazondashbutton:dashbutton:78-e1-03-98-69-00:press" triggered        // floor sprayed
	floorsprayed_timestamp.postUpdate(new DateTimeType())   //defaults to now
//Timestamp for sparying the floor
rule "Timestamp for spraying the floor"
	Item Floor_Trigger received command ON        // floor sprayed
//rule to reset the Switch
rule "Reset floor switch"
	Time cron "1 * * * * ?"
	if(Floor_Trigger.state==ON ) {
		    Floor_Trigger.sendCommand(OFF)
rule "Today Floor Spray Reset"
    Time cron "	0 0 1 1/1 * ? *"
   	Floor_Spray = 0
	Floor_Spray1.postUpdate(0)
Then my log just starts doing this… without any button press:
2019-04-06 12:53:47.688 [vent.ChannelTriggeredEvent] - amazondashbutton:dashbutton:78-e1-03-98-69-00:press triggered
2019-04-06 12:53:47.721 [INFO ] [ome.model.script.floor water counter] - 4
2019-04-06 12:53:47.748 [vent.ItemStateChangedEvent] - floorsprayed_timestamp changed from 2019-04-06T12:53:41.708-0400 to 2019-04-06T12:53:47.723-0400
2019-04-06 12:53:47.755 [vent.ItemStateChangedEvent] - Floor_Spray1 changed from 3 to 4
thoughts on this one?
perhaps the button is getting flaky? I can’t find anything wrong with the rules or logic but I’m a rule noob
Maybe the button doesn’t like the spraying? That might be a result of an electrically noisy pump causing interference etc., not just humidity.
You could enhance your rules to lock out (re)triggers for a period of time.
