2017-01-19 20:08:26.292 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Front Door Locked': An error occured during the script execution: null
How do I turn on debug for script execution to get a more detailed error log?
I also tried to set it up using JodaTime’s LocalTime() call but couldn’t even come close to figuring out how to pass formatting there (I’m 20 years removed from the last time I wrote code and it wasn’t in Java)
Here it is. Using LocalTime it works fine so it seems it’s something in my use of formatting.
rule "Front Door Locked"
Item Lock_GF_Living_LockButton received update
var String NowTime = String::format( "%1$tl:%1$tM %1$tp", new Date() )
// var DateTime NowTime = new LocalTime()
if (Lock_GF_Living_LockButton.state == 1) {
logInfo ("Front Door Lock","Locked" + NowTime)
sendBroadcastNotification("Front door locked at " + NowTime)
sendMail(mailTo, "Front Door Locked", "Door locked at " + NowTime)
I can’t see anything obvious when comparing your rule to the link you posted. However I haven’t checked whether it actually works but I’ll try it later tonight
Note: whenever I’ve used a date time in my rules I’ve used:
