Date/time format wrong
OH 4.3 snapshot
Hello again
I get this json data from rtl_433 via mqtt server
  "time": "2024-08-30 03:29:41",
  "model": "inFactory-TH",
  "id": 77,
  "channel": 1,
  "battery_ok": 1,
  "button": 0,
  "temperature_F": 64.5,
  "humidity": 80,
  "mic": "CRC"
Reading the time data creates a warning
2024-08-29 13:10:55.561 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command '2024-08-29 11:10:54' from channel 'mqtt:topic:MQTT_NAS:LS11:LS11_zuletztGesehen' not supported by type 'DateTimeValue': 2024-08-29 11:10:54 is not in a valid format
Whatā€˜s wrong with this data
Try regex transform s/ /T/
I canā€˜t select regex profil for date/time items
Did you install the RegEx Transformation add-on?
You can set the transformation pattern on the Mqtt thing channel, not profile
Regex transformation is installed
Unfortunately I need some help for regex command, haveā€™nt used it before.
Thats what I have for incoming value transformation, and whatā€™s needed for regex
jsonpath:$.time  āˆ©
Thatā€™s it. Put the regex I showed above at the end of it
That creates configuration error
JSONPATH:$.time āˆ©  regex transform s/ /T/
2024-08-30 15:36:03.970 [WARN ] [rnal.handler.GenericMQTTThingHandler] - Configuration error for channel 'mqtt:topic:MQTT_NAS:LS11:LS11_ZuletztGesehen'
java.lang.IllegalArgumentException: The transformation pattern must consist of the type and the pattern separated by a colon
	at org.openhab.binding.mqtt.generic.ChannelStateTransformation.<init>(ChannelStateTransformation.java:50) ~[bundleFile:?]
JSONPATH:$.timeāˆ©REGEX:s/ /T/
Thank you, it works. I tried that before but with blanks in between. It said, REGEX not found.
If this gets merged into 4.3, you can have spaces in there, or even specify it in multiple lines in UI without that intersection symbol.
Iā€™ve also submitted this PR so that core can just parse yyyy-MM-dd HH:mm without us needing to add a ā€œTā€ between the date and the time part
Multiple lines for commands on incoming value transformation works great in oh 4.3 4255
