Datepicker no hours and minutes anymore, OH 3.4.3 release build
Hi, I have a date picker in my widget and for some reason the hours and minutes are not showing anymore. I seem to remember it was below the calendar to select
here is the code:
                      - component: oh-input-item
                          title: Startzeit Automatik
                          type: datepicker
                          sendButton: true
                          validate: true
                          required: true
                          item: Zeit_Bewaesserung_Blumen
                          outline: false
                          calendarParams:
                            timePicker: true
                            locale: de
                            dateFormat: dd.mm.yyyy HH::mm:ss
                          style:
                            width: 85%
                            --f7-input-bg-color: "#ededed"
Thanks for pointing me in a direction to sort this out.
I think you need to use datetime-local to get both the date and the time, date and/or datepicker to just get the date and time to just get the time.
Thank you Rich, that did the trick!
