Hey chaps & chapettes,
I’m having a hard time transforming DateTime into something I can work with.
What I’m trying to do:
Send a push notification at 6pm in case the garbage will be picked up the next day. I have “garbage collection” as a datetime object in OH (MuellTime0 ). So I’ve started to code the following rule:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import java.util.Date
import java.lang.Double
import org.openhab.core.types.Command
import java.lang.Math
import java.util.Calendar
import java.util.GregorianCalendar
rule "Bring garbage outside"
Time cron "00 00 18 ? * *"
var DateTime alarm = now.plusHours(7) as DateTime
logInfo(“Muell Erinnnerung”, "MuellTime0 : " + MuellCalTime0.state)
logInfo(“Muell Erinnnerung”, "Now : " + now)
logInfo(“Muell Erinnnerung”, "Now +7h : " + alarm)
if (alarm.isAfter(MuellCalTime0.state)) {
logInfo(“Muell Erinnnerung”, “Muelltonne muss raus”)
} else {
logInfo(“Muell Erinnnerung”, “Muelltonne kann stehen bleiben”)
Logfile sais:
2016-04-28 13:52:00.267 [INFO ] [model.script.Muell Erinnnerung] - MuellTime0 : 2016-04-28T00:00:00
2016-04-28 13:52:00.327 [INFO ] [model.script.Muell Erinnnerung] - Now : 2016-04-28T13:52:00.327+02:00
2016-04-28 13:52:00.380 [INFO ] [model.script.Muell Erinnnerung] - Now +7h : 2016-04-28T20:52:00.114+02:00
2016-04-28 13:52:00.439 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Bring garbage outside
java.lang.IllegalStateException: Could not invoke method: org.joda.time.base.AbstractInstant.isAfter(long) on instance: 2016-04-28T20:52:00.114+02:00
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:738) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor50.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_77]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_77]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(XbaseInterpreter.java:549) ~[na:na]
at sun.reflect.GeneratedMethodAccessor51.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na]
at sun.reflect.GeneratedMethodAccessor91.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor59.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
Caused by: java.lang.IllegalArgumentException: argument type mismatch
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_77]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_77]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
… 29 common frames omitted
As you can see my variables/timestamps are filled ok but the if comparrison does not work. Can anyone give me a hint how to make it work?
Thanks much!
