Java Runtime Environment: the one that came with the image
openHAB version: 3.01
Issue of the topic: I need to do time comparisions within Rules in Java and feel really lost
I try to figure out how to perform a simple task in Java - tried 1000 things, read through the Forum but end up with failiures over and over again. Maybe someone can give me the right hint what Iâm doing wrong.
I read through all the Time conversion options and tried many of them, but again I mostly get errors.
maybe someone can help when I put the piece of code here in its actual state:
var LocalDateTime = Java.type(âjava.time.LocalDateTimeâ);
var logger = Java.type(âorg.slf4j.LoggerFactoryâ).getLogger(âorg.openhab.rule.â + ctx.ruleUID);
var ScriptExecution = Java.type(âorg.openhab.core.model.script.actions.ScriptExecutionâ);
now I want to know if the sun is already up, something like
//pseudocode//
if Jetzt > ZeitSonnenaufgang
do something
//end pseudo //
It seems so simple.
I tried many things but get conversion errors, most of the typeconversions in the forum here donât work for me and I have no idea anymore why? Am I missing some Installations/libraries or such?
Iâm not a Java programmer and not really familiar with it, but try to learn the hard way
Any help would be highly appreciated.
yes, working with the OH3 UI, no other IDE so far. ECMA it isâŠ
Actually with a very stupid workaround with string comparision it works, but this canât be the solution:
###SNIP
var Jetzt;
var ZeitSonnenaufgang;
var ZeitSonnenuntergang;
var strJetzt;
var strZeitSonnenaufgang;
var strZeitSonnenuntergang;
var comp1;
var comp2;
val Wecker_Android_Zeit = new DateTime(Wecker_Android.state.toString)
val Wecker_NestHub_Zeit = new DateTime(Wecker_NestHub.state.toString)
if ( Wecker_Android_Zeit.isAfter(Wecker_NestHub_Zeit)){
//do something
so for your case try:
if (now.isAfter(new DateTime(LokaleSonnendaten_Daylight_Start.state.toString))){
//do something
I just tried this with one of my items and got no syntax errors. This should work for you
logger.info("Logging geht")
if (now.isAfter(new DateTime(LokaleSonnendaten_Daylight_End.state.toString))){
logger.info("If Geht");
logger.info("Script durch");
Log:
2021-03-06 19:30:15.156 [INFO ] [org.openhab.rule.TestForum ] - Logging geht
2021-03-06 19:30:15.164 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'TestForum' failed: ReferenceError: "now" is not defined in <eval> at line number 4
It seems to me that some basics are missing. Any ideas?
Yeah, seems to work correctly now. But comments are still welcome as I, as a java-honk, donât know much about best practices in programming JS
Thanks for your answers!
var LocalDateTime = Java.type("java.time.LocalDateTime");
var ScriptExecution = Java.type("org.openhab.core.model.script.actions.ScriptExecution");
var Jetzt = new Date(new Date());
var ZeitSonnenaufgang = new Date(items["LokaleSonnendaten_Daylight_Start"]);
var ZeitSonnenuntergang= new Date(items["LokaleSonnendaten_Daylight_End"]);
logger.info('Aufgang: ' + ZeitSonnenaufgang);
logger.info('Untergang: ' + ZeitSonnenuntergang);
logger.info('Jetzt: ' + Jetzt);
if (Jetzt > ZeitSonnenaufgang && Jetzt < ZeitSonnenuntergang){
logger.info("Tag");
else {
logger.info("Nacht");
