That’s typically no error but a warning. You declared a variable (stAdvent) but did never use it. You can either just ignore it or use the variable in your rule. If you don’t use it, you can also delete it, since it makes no sense declaring a variable that is never used.
Thank you, ok
Here is the bit of the rule I think you are interested in…converts a time stamp string to Epoch to enable time calculations. Does not use the formatter but uses brute force to get timestamp into ISO8601 format.
rule "Heat pump return sensor 1 time stamp check"
Item MobileAlertsHeatPumpReturnSensorTimestamp received update
val String timestamp_str = MobileAlertsHeatPumpReturnSensorTimestamp.state.toString //from http cache and REGEX transform
val Number string_length = timestamp_str.length
if (string_length < 30) {
//Format string to ISO8601 stanard to for conversion to Epoch milliseconds
//logInfo("Mobile Alerts" , "<<<<<<< timestamp_str >>>>>>> = " + timestamp_str)
val timestamp_divided = timestamp_str.split(" ")
val date_str = timestamp_divided.get(0)
val time_str = timestamp_divided.get(1)
val meridiem_str = timestamp_divided.get(2)
val date_divided = date_str.split("\\/")
var daydate_str = date_divided.get(1) //Can be eg 1 or 11
val daydate_length = daydate_str.length
var month_str = date_divided.get(0) //Can be eg 1 or 11
val month_length = month_str.length
val year_str = date_divided.get(2)
val time_divided = time_str.split(":")
var hour_str = time_divided.get(0) //Can be eg 1 or 11
var Number hour_number = Integer::parseInt(hour_str) //Convert hour String to Number
val minutes_str = time_divided.get(1)
val seconds_str = time_divided.get(2)
//logInfo("Mobile Alerts" , "1 Split time: " + hour_str + " Hours " + minutes_str + " Minutes " + seconds_str + " Seconds " + meridiem_str + " Meridien" )
//Convert Meridien time to 24hr format
if (meridiem_str == "PM" && hour_number != 12) {
hour_number = hour_number + 12
//Add leading zeros if necessary
//Hour
if (hour_number < 10) {
hour_str = "0" + hour_number
else {
hour_str = hour_number.toString
//Day
if (daydate_length == 1) {
daydate_str = "0" + daydate_str
//Month
if (month_length == 1) {
month_str = "0" + month_str
//Re-assemble date and time to ISO 8601 formatted String
val timestamp_iso8601 = new String(year_str + "-" + month_str + "-" + daydate_str + "T" + hour_str + ":" + minutes_str + ":" + seconds_str + ".000+01:00")
logInfo("Mobile Alerts" , "1 ISO formatted timestamp = " + timestamp_iso8601)
//https://community.openhab.org/t/datetime-conversion-openhab-3-x/107197
//Convert String to to datetime type. Method #01
val DateTimeType DateTimeTypeFromString = DateTimeType.valueOf(timestamp_iso8601)
//logInfo("Mobile Alerts" , "DateTime from String = " + DateTimeTypeFromString)
//Convert Datetime type to Epoch millis. Method #08 variant A
val Number timestamp_epoch = (DateTimeTypeFromString).zonedDateTime.toInstant.toEpochMilli
//logInfo("Mobile Alerts" , "Epoch from DateTime variant A = " + timestamp_epoch)
//Calulculate elapsed time since timestamp
val Number currenttime = now.toInstant().toEpochMilli()
val Number elapsedtime_minutes = (currenttime - timestamp_epoch)/60000 //minutes
//logInfo("Mobile Alerts" , "Elapsed time mins = " + elapsedtime_minutes)
val Number elapsedtime_hours = elapsedtime_minutes/60 //hours
logInfo("Mobile Alerts" , "1 Heat pump return sensor last seen " + String::format("%.1f", elapsedtime_hours) + " hrs ago")
Perfect thx a lot. now my rule is working again, great
Would someone be able to tell me what I’m doing wrong. Have been stuck on this for ages. I’m trying to parse an almost ISO format string into a DateTime item but get the error Text ‘2021-01-16 20:05:10 +0000’ could not be parsed at index 20 in …
var String str = "2021-01-16 20:05:10 +0000"
var formatter = java.time.format.DateTimeFormatter.ofPattern("yyyy-MM-dd HH:mm:ss z");
postUpdate( ApcDate, ZonedDateTime.parse( str, formatter ) )
I managed to get it working. It’s a bit messy with some string replaces to make it an ISO date. I had hoped to use the DateTimeFormatter, but oh well it works.
str = str.replace(" +0000","+00:00").replace(" ","T")
postUpdate( str )
I am having troubles getting my head around these DateTime conversions.
Really want to migrate from 2 to 3 and have one remaining rule to convert.
now.plusMinutes(30).isBefore((ASTRO_SUNRISE_TIME.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
I tried various attempts but keep getting errors
Well you could use:
var sunrise = (Sunrise_Time.state as DateTimeType).getZonedDateTime()
sunrise.isBefore(now.minusMinutes(240))
or you convert (not tested):
now.plusMinutes(30).isBefore(sunrise.toInstant.toEpochMilli)
hth
I had the same problem converting from 2.5 to 3.
This worked for me:
val sunset = (LocalSun_Set_EndTime.state as DateTimeType).getZonedDateTime()
val sunrise = (LocalSun_Rise_StartTime.state as DateTimeType).getZonedDateTime()
if (now.plusMinutes(30).isAfter(sunset) || now.isBefore(sunrise)) {
Or in one line:
if (now.plusMinutes(30).isAfter(new sunset (LocalSun_Set_EndTime.state as DateTimeType).getZonedDateTime()) || now.isBefore(new sunset (LocalSun_Rise_StartTime.state as DateTimeType).getZonedDateTime())) {```
Hello to all and good afternoon,
Yesterday migrated to OH3 and I am loving it. I stumbled across some things regarding ZonedDateTime. I elaborated a simle rule in jython just as an example to whta I want to do that is do a simple postUpdate to a DateTime item like this:
from core.rules import rule
from core.triggers import when
from java.time import ZonedDateTime as DateTime
@rule("JythonLightControlTestRule", description="Jython Light Control Test Rule", tags=["admin"])
@when("Item SwitchLightsControlShortJython changed")
def jython_light_control_test_rule(event):
now = DateTime.now()
timeout = 10
if event.itemState == ON:
events.postUpdate(ir.getItem("DateTimeLightsControlLampJythonTimeoutControlLastUpdate"), str(now.plusSeconds(timeout)))
The issue is that the now.plusSeconds(timeout), if I print it out to the log it get’s printed with the timezone like this:
2021-01-30 15:51:26.017 [INFO ] [23.jython.JythonLightControlTestRule] - 2021-01-30T15:51:36.006681Z[Europe/Lisbon]
Afterwards I get an error:
IllegalArgumentException: java.lang.IllegalArgumentException: The argument 'state' must not be null.
This is for sure some simple conversion necessary, but from all the atemps I read I did not get there yet.
Could someone be so kind and give ma hand on this, please?
Thank you very much in advanced.
Hello again,
I found a way that work, do not know if it is the most correct one but it works, By adding .toLocalDateTime() in postUpdate it works now:
timeout = 10
events.postUpdate(ir.getItem("DateTimeLightsControlLampJythonTimeoutControlLastUpdate"), str(now.plusSeconds(timeout).toLocalDateTime()))
Thanks.
My rule looks like this:
from core.actions import ScriptExecution
@rule("Turn on ZWaveNode089FGS222DoubleRelaySwitch2X15KWSwitchBinary1 after motion sensor is triggered", description="Turn on Flood light after motion is detected", tags=["Tag 1", "Tag 2"])
@when("Item ZWaveNode104SP816SP816MotionSensorAlarmMotion changed")
def ZWaveNode104SP816SP816MotionSensorAlarmMotion(event):
if items["Naplemente_Kapcsolo"] == ON and items["Overwind"] == OFF:
if items["ZWaveNode104SP816SP816MotionSensorAlarmMotion"] == ON:
events.sendCommand("ZWaveNode089FGS222DoubleRelaySwitch2X15KWSwitchBinary1", "ON")
ScriptExecution.createTimer(DateTime.now().plusSeconds(120), lambda:(ZWaveNode104SP816SP816MotionSensorAlarmMotion_2(OFF)))
def ZWaveNode104SP816SP816MotionSensorAlarmMotion_2(event):
if items["ZWaveNode104SP816SP816MotionSensorAlarmMotion"] == OFF:
events.sendCommand("ZWaveNode089FGS222DoubleRelaySwitch2X15KWSwitchBinary1", "OFF")
else: ZWaveNode104SP816SP816MotionSensorAlarmMotion(ON)
Hello, I am currently migrating from OpenHAB 2.5 to 3.0. I really like the semantic model but I am struggling with migrating from Jodatime to Java Time API. I am not a programmer and guess there is a trivial solution. How do I translate these few lines?
var Number hour = now.getHourOfDay
var Number day = now.getDayOfWeek
var Number month = now.getMonthOfYear
Thanks so much!
Take a look at this post:
I think it will help with what you are looking for.
Best regards
Thanks, it works for
now.getMonthValue
now.getHour
what I am missing is the day of the week either as a number or name.
Take a look at this thread:
I think it can help you.
Best regards.
That does actually work for a ZonedDateTime, but returns an complex object. Try -
var Number day = now.getDayOfWeek.getValue
I am finalizing a rule for OH3 and struggling with the conversion. Probably an easy one for the community to give me the right hint.
> rule "Biotonne Erinnerung"
> when
> Time cron "0 30 9 * * ? *"
> then
> val ZonedDateTime zdt = ZonedDateTime.now()
> val ZonedDateTime pickupDateCompare = zdt.toLocalDate().atStartOfDay(zdt.getOffset())
> val GarbagePickup = (garbage_collection_bioabfall.state as DateTimeType).getZonedDateTime()
> val FuturePickupDate = pickupDateCompare.plusDays(2)
> if( FuturePickupDate > GarbagePickup ) {
> val telegramAction = getActions("telegram","telegram:telegramBot:Telegramxxxxx")
> telegramAction.sendTelegram(xxxxxxxxx, "Denke an die Biotonne!!! Die Abholung ist am " + garbage_collection_bioabfall.state.toString()+".")
> logInfo ("Biotonne", "Denke an die Biotonne!!! Die Abholung ist am " + garbage_collection_bioabfall.state.toString()+"." )
> end
The rule is working but I am struggling to understand how to format the Date of the output to make it dd:mm:yyyy like in the UI. this is how the output currently looks like:
Denke an die Biotonne!!! Die Abholung ist am 2021-02-08T00:00:00.000+0100
displayState.toString is not supported here in the rule. I am getting an error message.
Thanks!
You’ve already got it as a ZonedDateTime, let’s use that
GarbagePickup.format(DateTimeFormatter.ofPattern("dd:MM:yyyy")
