I never knew about withTime. That can eliminate a lot of the withTimeAtStartOfDay.plusHours stuff. I’m surprised there isn’t a with date that works the same.
Thought I brought it up in a DST conversation in the ToD DP thread as an alternative to withTimeAtStartOfDay, since it is DST safe. Sorry for being OT, but this is very handy with Intervals…
import org.joda.time.Interval
import org.joda.time.Days
if (new Interval(now.withTime(9,0,0,0), now.withTime(17,0,0,0)).contains(now)) {
// do stuff between 9am and 5pm
Another use of Interval with a DateTime Item…
if (new Interval(Days.days(7), new DateTime(Sun_Eclipse_Total.toString)).contains(now)) {
// do eclipse stuff
I want to get the time into a datetime item, so it would be #1 i think? No variable with joda-datetime.
But my given string is in the format “2018-10-25 11:00”. So there is no “T” and no “+02:00” inside it… So how can i change this given string-item into a datetime-item?
Looks like it will be affected. Thank you for that information.
I would not update this threat until the new version 2.4 is released.
What do you think?
Because the breakage is bigger than expected there is discussion of going back to joda for the time being or figuring out a way to get those missing methods back. Watch the pr thread for details. I wouldn’t do anything until that gets resolved.
I have searched and searched, but need some help. Maybe somebody ( @rlkoshak? ) knows the trick I need or what I’m doing wrong…
Trying to instantiate a DateTime with the epoch milliseconds not from calendar or now.millis but from a number item (set by Android HAAS app). I am multiplying by 1000 to get milliseconds first and storing result as a Number. When I try to use DateTime constructor though I get an Error. I have tried to explicitly set the ‘alarmTime’ variable as a long and other things, but nothing seems to work. Here is the relevant code:
val Number milliseconds = (Bedside_Light_Alarm_DateTime.state as Number) * 1000
logInfo("Debugging DateTime crap...", "The milliseconds is: " + milliseconds)
val DateTime alarmTime = new DateTime(milliseconds)
logInfo("Debugging DateTime crap...", "The alarmTime Calender/DateTime is: " + alarmTime.toString)
2019-01-14 10:26:38.786 [INFO ] [el.script.Debugging DateTime crap...] - The milliseconds is: 1547506800000
2019-01-14 10:26:38.789 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Bedroom Light Alarm Updated': No instant converter found for type: java.math.BigDecimal
Number AlarmClock
DateTime Alarmzeit "Alarmzeit [%1$tH:%1$tM]"
This rule…
rule "Alarmzeit"
Item AlarmClock changed
val DateTimeType MyDateTimeTypeFromEpoch = new DateTimeType(new DateTime(AlarmClock).toString)
logInfo("Algemein.rules",MyDateTimeTypeFromEpoch.toString)
causes this error…
2019-05-01 19:47:28.139 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Alarmzeit': No instant converter found for type: org.eclipse.smarthome.core.library.items.NumberItem
What is wrong in my converting? Maybe someone can help.
rule "Alarmzeit"
val DateTimeType MyDateTimeTypeFromEpoch = new DateTime(AlarmClock.state.toString)
Now there is a differnt error:
2019-05-01 22:03:56.828 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Alarmzeit': Invalid format: "1556769600000" is malformed at "0000"
Sorry Rich,
still not working. How hard could it be to convert a ordinary number.
rule "Alarmzeit"
val DateTimeType MyDateTimeTypeFromEpoch = new DateTime((AlarmClock.state as Number).longValue)
2019-05-04 14:10:14.611 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Alarmzeit': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.core.library.types.DateTimeType.toString() on instance: 2019-05-04T14:20:17.795+02:00
DateTime and DateTimeType are not the same thing. You’ve declared the available to be DateTimeType but you are creating a DateTime to store in the variable.
