I’m having a weird issue here, not sure what I could be doing wrong.
I have this door contact
And for the open/state channel I added two items. One without a profile - it represents the open/closed state. It doesn’t have any state description (but probably gets something from the binding/thing).
The second item that I created for the same channel, is a timestamp item with the link profile to update it when the channel state changes.
Works fine so far, I get the desired timestamp for every change.
Now I want to use this in the main ui and set up a state description for the item and set this pattern:
%1$td. %1$tm. %1$tR
I use this pattern on other timestamp items, so I know it works fine.
However, it isn’t applied to this item here, I still see the raw timestamp in the ui, no state description metadata applied.
When I look up the item in the expression tester, I don’t get a displayState at all:
{ "state": "2021-05-07T09:10:18.724+0200" }
Now, when I fetch the item in the api explorer, I get the pattern BUT I additionally get a state description for open/close …
I guess this is inherited from the channel somehow?
"link": "http://192.168.0.199:8080/rest/items/Haustur_LastOpenState",
"state": "2021-05-07T09:10:18.724+0200",
"stateDescription": {
"pattern": " %1$td. %1$tm. %1$tR",
"readOnly": true,
"options": [
"value": "CLOSED",
"label": "geschlossen"
"value": "OPEN",
"label": "offen"
"commandDescription": {
"commandOptions": [
"command": "CLOSED",
"command": "OPEN",
"label": "offen"
"editable": true,
"type": "DateTime",
"name": "Haustur_LastOpenState",
"label": "Letztes Mal geöffnet",
"category": "time",
"tags": [
"Point"
"groupNames": [
"Haustur"
I assume this is the cause of the problem, yet the raw timestamp still shows up.
And to make things worse/weirder:
At some point I got this in the log, but I can’t reproduce it .
2021-05-07 10:19:47.702 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: H
2021-05-07 10:19:47.705 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Ha
2021-05-07 10:19:47.707 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Hau
2021-05-07 10:19:47.710 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haus
2021-05-07 10:19:47.713 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haust
2021-05-07 10:19:47.716 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustu
2021-05-07 10:19:47.718 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_
2021-05-07 10:19:47.721 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_L
2021-05-07 10:19:47.724 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_La
2021-05-07 10:19:47.727 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_Lat
2021-05-07 10:19:47.730 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_Las
2021-05-07 10:19:47.732 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_Last
2021-05-07 10:19:47.735 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastO
2021-05-07 10:19:47.738 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOp
2021-05-07 10:19:47.740 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOpe
2021-05-07 10:19:47.743 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOpen
2021-05-07 10:19:47.746 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOpenS
2021-05-07 10:19:47.748 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOpenSt
2021-05-07 10:19:47.751 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOpenSta
2021-05-07 10:19:47.753 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: Haustur_LastOpenStat
2021-05-07 10:19:47.757 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: anycubic_Timestampoflastprogressmessag
2021-05-07 10:19:47.760 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: anycubic_Timestampoflastprogressmessa
For the moment my solution is to use a rule to update an “independent” item that isn’t linked to the thing at all. But I wonder what the problem is with the much more elegant solution of using a profile.
In case that it’s a known bug, I’m still on the 3.0.0 release build at the moment
