DateTime operations
For anyone following this thread, the mentioned PR is this one:
You are right that I didn’t anticipate that Rules DSL would log deprecation notices when loading rules. Unfortunately there is strong coupling between Rules DSL and core types.
I’m not sure if the deprecation itself is a mistake though, but I am somewhat divided. The issue is that previously you would get back the time-zone that was provided when creating the DateTimeType. If the item was updated by a binding, this might be the configured time-zone in openHAB - or system time-zone or UTC, depending on the binding.
Now, you will get system time-zone, because that’s the only time-zone which is possible to obtain within the DateTimeType instance. Therefore the functionality had to change, and IMHO this ambiguity is a good reason for deprecating the method, and instead promote getZonedDateTime(ZoneId) in order to have consistent and predictable results. Especially for addons, this should lead to refactoring so that the desired time-zone is always explicitly provided. I already prepared a PR for that, so that we’ll no longer be using the deprecated methods:
On the other hand, it might be desirable to be less strict for Rules DSL since this is user-provided rules, and for most users the system time-zone will be the same as the time-zone configured in openHAB. However, fundamentally the problem is the same in rules as in addons, so in the long run, I still think it would be better to avoid relying implicitly on the time-zone, as it could lead to some unexpected behavior.
Unfortunately, because of the tight coupling, there is no way of deprecating the method for core/addons Java development, but not for Rules DSL. So I think not deprecating it now will just postpone the problem. And all DSL rules will still continue to work, even with the deprecation notices logged.
For completeness, this deprecation shouldn’t affect any other rule languages. It has been verified at least that JavaScript doesn’t log anything, and it will only require a small change in the beginning of the 5.0 development cycle to stop using the deprecated method, and instead use the time-zone configured in openHAB. This will lead to a more consistent behavior than prior to 4.3 (the “breaking change” label is misleading, it won’t be breaking):
