Seems to be a never ending story…
I once had a DateTime Item with a time stamp. To get this time stamp back when restarting openHAB, I decided not to store this time stamp separately but to get the time stamp from persistence service:
MyItem_LastUpdate.postUpdate(DateTimeType::DATE_FORMATTER_WITH_TZ.format(MyItem.lastUpdate("mysql")))
Well, this stopped working around 09-2015, I’m using openHAB quite a while…
The solution was this code snippet:
import java.util.Calendar
var Calendar cal = Calendar::getInstance()
cal.setTime(MyItem.lastUpdate("mysql"))
MyItem_LastUpdate.postUpdate(new DateTimeType(cal))
And this code is reliable since then (orirginal posting here, thanks @watou)
But as DateTimeType(Calendar)
now is deprecated, I’m a bit lost. I could not get things to work without DateTimeType. The code is still working, but openHAB complains about, so better change it now…
