Likely that was just a new build of the jar file. According to GitHub the binding was last updated January 13 to add 2020 copyright. All that information is publicly available in GitHub. Anybody can search just like I did.
The Davis binding was never formally confirmed to work with openHAB 2. Which means nobody added it to the feature file of openHAB 1 bindings. As a result you won’t find it in the list of bindings to install, and the reason it won’t show in PaperUI. Given the fact openHAB 3 won’t support openHAB 1 bindings there is no active development on openHAB 1 bindings, so I doubt it will ever be possible to install this openHAB 1 binding via the normal route. Unless someone creates a openHAB 2 version. The only way to install this openHAB 1 binding is to manually install the binding as suggested here.
I’ve followed the steps to manually install the binding.
1 Copied org.openhab.binding.davis-1.15.0-SNAPSHOT.jar to /usr/share/openhab2/addons
2 Set permissions.
3 Created items
4 Added the following to my sitemap file.
Frame label=“Davis Vantage Pro 2” {
Group item=DavisWeather
but it doesn’t work no values shown in ClassicUI, no errors in log.
Where should I go from here?
