I am running openHAB 2.4 on an Ubuntu Linux server. I am brand new to openHAB. I have a Davis VantagePro2 with an IP dongle. How would I go about binding this so that I can view the current temperature on the basic UI. I would ultimately like to configure it to work on the HABPANEL as well.
I visited that guide and I wasn’t sure exactly what I needed to do. It appears that you have to search for the binding and then install it but I cannot find any davis bindings in the search. Do I create my own "davis.cfg in the services folder? If so what goes in that cfg file? Thanks.
Hmmmm that could be because it’s a 1.X binding so a little older.
You need to enable 1.X Bindings in your Paper UI > configuration > system “Include Legacy 1.x Bindings”
Then try to search again.
