namraccr
(namraccr)
April 10, 2018, 5:15am
1
If any current users of the Davis weather binding would like to try out a new version enabling IP communication, please try this jar from this PR .
The author has decided not to complete the changes, but if someone can confirm it’s working, we can push the PR to completion…
Thanks!
redalert
(новичек)
October 30, 2018, 6:49pm
2
Having Davis Vantage Pro2 Plus with Wireless Weather Envoy (IP).
Tried to download and install this jar binding file.
Have OpenHAB 2.4 snapshot installed on RPi.
Stopped OH
Copied provided jar file into following folder /usr/share/openhab2/addons
changed permissions to openhab:openhab
Started OH
Can you correct if I missing something in order to make this binding working and I could verify it with my weather station?
namraccr
(namraccr)
October 30, 2018, 10:51pm
3
That sounds like it should work, assuming you set up the config for the binding.
redalert
(новичек)
October 31, 2018, 7:04pm
4
Yep, I’ve configured according this manual Davis Binding
My configuration file under services/davis.cfg is:
hostName=192.168.1.7
readResponseWaitTime=1000
refresh=10000
Karaf shows that Davis binding is active:
223 x Active x 80 x 1.12.0.201805280013 x openHAB Davis Binding
OH2 is also not showing any errors when binding is started:
[DEBUG] [org.openhab.binding.davis ] - BundleEvent STARTING - org.openhab.binding.davis
[DEBUG] [inding.davis.internal.DavisActivator] - Davis binding has been started.
[DEBUG] [org.openhab.binding.davis ] - BundleEvent STARTED - org.openhab.binding.davis
[DEBUG] [org.openhab.binding.davis ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={service.id=383, service.bundleid=223, service.scope=bundle, event.topics=openhab/*, service.pid=org.openhab.davis, component.name=org.openhab.binding.davis, component.id=236} - org.openhab.binding.davis
[TRACE] [.binding.davis.internal.DavisBinding] - update() method is called!
[DEBUG] [org.openhab.binding.davis ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.davis.DavisBindingProvider}={service.id=382, service.bundleid=223, service.scope=bundle, component.name=org.openhab.binding.davis.genericbindingprovider, component.id=237} - org.openhab.binding.davis
From Davis binding log that’s it, no more log data, seems that it is not trying to connect to configured Davis host, since there should be another log entry when opening port (serial or IP) in case of success or failure.
I’am currently running OH 2.4.0-SNAPSHOT Build #1403 version.
Any ideas what else I could try?
namraccr
(namraccr)
November 2, 2018, 11:58pm
5
What’s your configuration/sitemap?
redalert
(новичек)
November 7, 2018, 10:24pm
6
I took configuration from example that was in Davis Binding manual.
Here is my davis.items file
Group DavisWeather "Current weather" <sun_clouds>
Group DavisStation "Station data" (DavisWeather)
Group DavisInfo "Info" (DavisWeather)
Group DavisTemperature "Temperature" (DavisWeather)
Group DavisHumidity "Humidity" (DavisWeather)
Group DavisBarometer "Barometer" (DavisWeather)
Group DavisWind "Wind" (DavisWeather)
Group DavisRain "Rain" (DavisWeather)
Group DavisSun "Solar information" (DavisWeather)
String StationType "StationType: [%s]" (DavisStation) { davis="station_type" }
Number Receivers "Receivers: [%.0f]" (DavisStation) { davis="receivers" }
Number TransmitterBattery "Transmitter Battery [%.1f]" (DavisStation) { davis="transmitter_battery_status" }
Number ConsoleBattVoltage "Console Battery [%.2f V]" (DavisStation) { davis="console_battery_voltage" }
String firmware_date "Firmware Date: [%s]" (DavisStation) { davis="firmware_date" }
String firmware_version "Firmware Version: [%s]" (DavisStation) { davis="firmware_version" }
DateTime Date "Date [%1$tA, %1$td.%1$tm.%1$tY]" (DavisInfo) { davis="time" }
Number InsideTemp "Inside Temp [%.1f °C ]" (DavisTemperature) { davis="inside_temp" }
Number OutsideTemp "Outside Temp [%.1f °C ]" (DavisTemperature) { davis="outside_temp" }
Number DewPoint "Dew Point [%.1f °C ]" (DavisTemperature) { davis="dew_point" }
Number HeatIndex "Heat Index [%.1f °C ]" (DavisTemperature) { davis="heat_index" }
Number WindChill "Wind Chill [%.1f °C ]" (DavisTemperature) { davis="wind_chill" }
Number THSWIndex "THSW Index[%.1f °C ]" (DavisTemperature) { davis="thsw_index" }
Number InsideHumidity "Inside Humidity [%.0f %% ]" (DavisHumidity) { davis="inside_humidity" }
Number OutsideHumidity "Outside Humidity [%.0f %% ]" (DavisHumidity) { davis="outside_humidity" }
String BarTrend "Barometer Trend [%s]" (DavisBarometer) { davis="bar_trend" }
Number Barometer "Barometer [%.0f hPa]" (DavisBarometer) { davis="barometer" }
Number WindSpeed "Wind Speed [%.1f km/h]" (DavisWind) { davis="wind_speed" }
Number WindSpeed10minAvg "Wind Speed 10min Avg [%.1f km/h]" (DavisWind) { davis="wind_speed_10min_avg" }
Number WindDirection "Wind Direction [%.0f °]" (DavisWind) { davis="wind_direction" }
Number WindSpeed10minHiRes "Wind Speed 10min Avg HiRes [%.1f km/h]" (DavisWind) { davis="wind_speed_10min_avg_hires" }
Number WindSpeed2minHiRes "Wind Speed 10min Avg HiRes [%.1f km/h]" (DavisWind) { davis="wind_speed_2min_avg_hires" }
Number WindSpeed10minGustHiRes "Wind Speed 10min Avg HiRes [%.1f km/h]" (DavisWind) { davis="wind_speed_10min_gust_hires" }
Number WindDirectionGust "Wind Direction Gust [%.0f °]" (DavisWind) { davis="wind_direction_10min__gust" }
Number RainRate "Rain Rate [%.1f mm/h ]" (DavisRain) { davis="rain_rate" }
Number Rain15min "Rain Rate [%.1f mm/h ]" (DavisRain) { davis="last_15min_rain" }
Number Rainlast1h "Rain Rate [%.1f mm/h ]" (DavisRain) { davis="last_hour_rain" }
Number Rainlast24h "Rain Rate [%.1f mm/h ]" (DavisRain) { davis="last_24h_rain" }
Number UVIndex "UV Index [%.1f ]" (DavisSun) { davis="uv" }
Number Solar "Solar Radiation [%.0f W/m²]" (DavisSun) { davis="solar_radiation" }
Davis part of a .sitemap
Frame label="Meteo" {
Group item=DavisWeather
namraccr
(namraccr)
November 8, 2018, 12:01am
7
If the updated binding were properly installed, you should see this message in the log:
ProperlyConfigured with hostName [hostname] with readResponseWaitTime on
redalert
(новичек)
November 8, 2018, 10:06am
8
No, I have not seen this message in a log files. The log I’ve attached previously is all I see currently.
For Davis binding I’ve set the TRACE log level through karaf console
log:set TRACE org.openhab.binding.davis
I try to install the binding but i received this error message:
2019-01-05 18:25:08.276 [ERROR] [org.openhab.binding.davis ] - [org.openhab.binding.davis(279)] The deactivate method has thrown an exception
at org.openhab.binding.davis.internal.DavisBinding.closePort(DavisBinding.java:191) [265:org.openhab.binding.davis:1.12.0.201805280013]
at org.openhab.binding.davis.internal.DavisBinding.deactivate(DavisBinding.java:71) [265:org.openhab.binding.davis:1.12.0.201805280013]
lukqw
(lukqw)
June 5, 2019, 11:18am
10
@namraccr
I’m currently trying to connect a Davis Weather Envoy to my openhab2.4 system. This is a totally fresh install.
I installed your jar in the following way:
systemctl stop openhab2
placing your jar in /usr/share/openhab2/addons
changed the permissions like @redalert
systemctl start openhab2
Then I ran into various problems which I found in the logs:
Unresolved requirement: Import-Package: gnu.io
fixed by “feature:install openhab-transport-serial” in karaf
Unresolved requirement: Import-Package: org.openhab.core.binding
fixed by “feature:install openhab-runtime-compat1x”
Now the binding seems to start successfully since there are no errors anymore.
I created a services/davis.cfg
hostName=192.168.111.77
refresh=10000
An item file in items/davis.items with the exact content as in the bottom example of https://www.openhab.org/addons/bindings/davis1/
And a sitemap in sitemaps/test.sitemap with a Text element for each of the items of above.
When restarting openhab, the logs look like this (after everything has stopped):
2019-06-05 13:16:40.524 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-06-05 13:16:40.586 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-06-05 13:16:48.127 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'davis.items'
2019-06-05 13:16:51.284 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-06-05 13:16:52.245 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
2019-06-05 13:16:53.295 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.111.71:8080
2019-06-05 13:16:53.298 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.111.71:8443
2019-06-05 13:16:53.857 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-06-05 13:16:53.886 [DEBUG] [org.openhab.binding.davis ] - BundleEvent STARTING - org.openhab.binding.davis
2019-06-05 13:16:53.893 [DEBUG] [inding.davis.internal.DavisActivator] - Davis binding has been started.
2019-06-05 13:16:53.898 [DEBUG] [org.openhab.binding.davis ] - BundleEvent STARTED - org.openhab.binding.davis
2019-06-05 13:16:53.917 [DEBUG] [org.openhab.binding.davis ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.davis.DavisBindingProvider}={service.id=341, service.bundleid=198, service.scope=bundle, component.name=org.openhab.binding.davis.genericbindingprovider, component.id=202} - org.openhab.binding.davis
2019-06-05 13:16:54.317 [DEBUG] [org.openhab.binding.davis ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={service.id=354, service.bundleid=198, service.scope=bundle, event.topics=openhab/*, service.pid=org.openhab.davis, component.name=org.openhab.binding.davis, component.id=201} - org.openhab.binding.davis
2019-06-05 13:16:54.358 [TRACE] [.binding.davis.internal.DavisBinding] - update() method is called!
Do you have any idea on how to solve this?
Thanks & best regards
lukqw
namraccr
(namraccr)
June 5, 2019, 11:38am
11
Solve what? You just said the binding is starting successfully.
And your log snippet doesn’t show any problems.
lukqw
(lukqw)
June 5, 2019, 11:41am
12
Sorry!
It’s not working for me, I can’t get any values from the davis weather envoy.
namraccr
(namraccr)
June 5, 2019, 11:57am
13
Check the list of running bundles to verify the old davis binding is not running and the new one is.
You might also need to clear the cache, as your output seems to show no davis settings being found.
lukqw
(lukqw)
June 5, 2019, 2:31pm
16
I think there are no davis settings being found because the config seems to be null @ line 163 in DavisBinding.java. Where should i place the davis.cfg file exactly? /etc/openhab2/services or somewhere else?
namraccr
(namraccr)
June 5, 2019, 10:58pm
17
As the docs point out, it should be $OPENHAB_CONF/services/.
In windows this is runtime/conf/services/. No clue where it lands in other platforms.
lukqw
(lukqw)
June 12, 2019, 1:30pm
18
Well I placed the config in /etc/openhab2/services/davis.cfg and it also seems to be loaded, because karaf console gives me the following output when I enter config:list:
Pid: org.openhab.davis
BundleLocation: file:/usr/share/openhab2/addons/org.openhab.binding.davis-1.12.0-SNAPSHOT.jar
Properties:
hostName = xxx.xxx.xxx.xxx
readResponseWaitTime = 1000
service.pid = org.openhab.davis
But it’s still not working as intended, I don’t get the message in the logs:
I also tried placing a config file with both, a port and Hostname, in the same directory and it also got loaded. But there is a thing I don’t understand which needs some sourcecode:
if (config != null) {
// to override the default refresh interval one has to add a
// parameter to openhab.cfg like <bindingName>:refresh=<intervalInMs>
String refreshIntervalString = (String) config.get("refresh");
if (StringUtils.isNotBlank(refreshIntervalString)) {
refreshInterval = Long.parseLong(refreshIntervalString);
String newPort = (String) config.get("port"); //$NON-NLS-1$
String newHostName = (String) config.get("hostName"); //$NON-NLS-1$
if (StringUtils.isBlank(newPort) && StringUtils.isBlank(newHostName)) {
logger.error("neither port neither hostname configured, no communication possible");
setProperlyConfigured(false);
} else {
if (StringUtils.isNotBlank(newPort) && StringUtils.isNotBlank(newHostName)) {
logger.warn(
"both properties port and hostname configured, only one should be set according communication type serial (port) or IP (hostname)");
This is straight out of the DavisBinding.java. As you can see in the last ‘else’ block:
if the newPort is not blank and the hostName is also not blank - if both are provided - the warning should be logged. But it’s not getting logged!
Do you have any idea how I can check if the config is not null at the first if?
namraccr
(namraccr)
June 12, 2019, 10:30pm
19
In current code, this is not possible. If I can steal a few minutes, I’ll make a version that spits out a debug message if the config is null.
lukqw
(lukqw)
June 25, 2019, 3:14pm
21
I tried your version and then the previous one because now it just works.
I have no idea why it suddenly works and I think it has to do with my network because I just moved the setup to a new place.
namraccr
(namraccr)
June 25, 2019, 10:57pm
22
Glad to hear it.
I’ll look into getting this merged.
