Me too! I don’t wont to have the hassle of installing and maintaining a database server, if not needed.
I did some tests with db4o and sqlite and compared the results from the persistence functions. Everything seems to be plausible so far. But this was, by no means, an extensive test.
My only complaint is that you gracefully handle a query that has no data. So when you 0 out your db and your rules first run they error on not finding the data. I at least have not found a way to test if the data is there is not use a default value and not error.
val double today_grid = if(Today_Grid_kWh.previousState().state == null) 0 else Today_Grid_kWh.previousState().state
However if I start with a clean db that throws and error because there is no Today_Grid_kWh previous state in the db. I have been getting past this for now by manually entering data in my db after I clear my db, but I would like to not do that manually.
rule "Today Grid Used"
Item Grid_wh changed
val double previous_meter = Grid_wh.previousState(true, "db4o").state
val double current_meter = Grid_wh.state
logInfo("Testing", "Current: " + current_meter)
logInfo("Testing", "Previous: " + previous_meter)
val double today_grid = if(Today_Grid_kWh.state == null) 0 else Today_Grid_kWh.state
postUpdate(Today_Grid_kWh, today_grid + ((current_meter - previous_meter)/1000))
Error with Today_Grid_kWh NOT in db yet.
2017-01-22 18:28:43.585 [INFO ] [g.openhab.model.script.Testing] - Current: 33796387.885
2017-01-22 18:28:43.630 [INFO ] [g.openhab.model.script.Testing] - Previous: 33796365.197
2017-01-22 18:28:43.650 [INFO ] [runtime.busevents ] - Creek_Level state updated to 2.42
2017-01-22 18:28:43.656 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule 'Today Grid Used'
at org.openhab.model.script.lib.NumberExtensions.operator_equals(NumberExtensions.java:81) ~[na:na]
at sun.reflect.GeneratedMethodAccessor115.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_66]
at java.lang.reflect.Method.invoke(Method.java:497) ~[na:1.8.0_66]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:729) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:713) ~[na:na]
at sun.reflect.GeneratedMethodAccessor79.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.openhab.model.script.interpreter.ScriptInterpreter.internalFeatureCallDispatch(ScriptInterpreter.java:69) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAbstractFeatureCall(XbaseInterpreter.java:658) ~[na:na]
at sun.reflect.GeneratedMethodAccessor78.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(XbaseInterpreter.java:327) ~[na:na]
at sun.reflect.GeneratedMethodAccessor91.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(XbaseInterpreter.java:601) ~[na:na]
at sun.reflect.GeneratedMethodAccessor82.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor84.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.core.scriptengine.ScriptExecutionThread.run(ScriptExecutionThread.java:44) ~[na:na]
