Hello, I would like to know in which cases a node is marked as DEAD/FAILED?
Quotes from docu:
DEAD - A device is considered DEAD if it does not respond to a message three times.
If I understand correctly this functionality should use incrementResendCount() method in ZWaveNode class. But the problem is that the method is never called.
The second thing I would like to mention is that in IsFailedNodeMessageClass class node is never marked as FAILED due to commented line 57
Github is to raise bugs and problems - support questions about how things work really should be discussed on the community forum.
I think you have answered this -:
A DEAD device may then be marked as FAILED, but if I remember correctly this may have been removed as it caused a problem. At the end of the day there is little difference between DEAD and FAILED - DEAD is an internal binding state, FAILED is managed by the controller. The binding should treat both states the same way.
The only functional difference should be that a device can only be removed from the controller if the controller thinks the device has failed.
