Hello, minor puzzle here, I set parameter 11 of my Fibaro multisensor (switches and temperatures, mains operated) to 255, its max value, as defined in the database’s XML;
"id": 11,
"label": "Interval betw. forcing to send report for temp.",
"description": "The forced report is sent immediately after ...",
"overview": "<p>... the next reading of temperature from the sensor, irrespective of the settings<br \/>of parameter no. 12.<br \/>Default value: 200 s<br \/>Possible parameter settings:<br \/>0 \u2013 255 s<br \/>0 \u2013 deactivating the function<br \/>Note: Frequent sending of temperature condition reports is<br \/>reasonable when the sensor is located somewhere where can<br \/>occure rapid changes of ambient temperature. In other cases<br \/>it is recommended to leave the parameter set to the default<br \/>value.<\/p>",
"size": 1,
"bitmask": "00000000",
"default": 200,
"read_only": false,
"write_only": false,
"value_min": 1,
"value_max": 255,
"options": []
This was reported in the debug as the value being set to “-1” which caused me some minor confusion. Setting the variable to 254 showed in the debug as -2.
NODE 41: Node configuration report, parameter = 11, value = -1, size = 1
Pretty minor but just flagging it up in case it’s indicative of anything else.
dbReference | 126 |
defaultAssociations | 3 |
manufacturerId | 010F |
manufacturerRef | 0501:0102,0501:0109,0501:1002,0501:2002,0501:3002,0501:4002 |
modelId | FGBS001 |
vendor | Fibargroup |
