Thanks! Should have looked there in the first place.
I now have a debug logs for the node from when I set it to the opened and closed orientations. I’m seeing this line, NODE 52: Alarm converter NOTIFICATION event is 22, channel alarm_access is not implemented.
That’s one of the channels which I’ve subscribed to but which does not appear in Paper UI. What’s a reasonable next step?
Door sensor set to opened orientation:
2020-05-26 16:25:43.300 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 34 0B 71 05 00 00 00 FF 06 16 00 00 00 4E
2020-05-26 16:25:43.301 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 0B 71 05 00 00 00 FF 06 16 00 00 00
2020-05-26 16:25:43.301 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 0B 71 05 00 00 00 FF 06 16 00 00 00
2020-05-26 16:25:43.301 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-26 16:25:43.301 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Application Command Request (ALIVE:REQUEST_NIF)
2020-05-26 16:25:43.301 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-05-26 16:25:43.301 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: SECURITY not supported
2020-05-26 16:25:43.301 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 52: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-05-26 16:25:43.301 [DEBUG] [ernal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 52: NOTIFICATION report - 0 = 0, event=22, status=255, plen=0
2020-05-26 16:25:43.301 [DEBUG] [ernal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 52: Alarm Type = ACCESS_CONTROL (0)
2020-05-26 16:25:43.301 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-05-26 16:25:43.301 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-05-26 16:25:43.301 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter processing NOTIFICATION
2020-05-26 16:25:43.302 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter NOTIFICATION event is 22, type OnOffType
2020-05-26 16:25:43.302 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter processing NOTIFICATION
2020-05-26 16:25:43.302 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter NOTIFICATION event is 22, channel alarm_access is not implemented.
2020-05-26 16:25:43.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Commands processed 1.
2020-05-26 16:25:43.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@368fb280.
2020-05-26 16:25:43.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-26 16:25:43.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-26 16:25:43.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-26 16:25:43.317 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 34 04 30 03 FF FF F2
2020-05-26 16:25:43.318 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 04 30 03 FF FF
2020-05-26 16:25:43.318 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 04 30 03 FF FF
2020-05-26 16:25:43.318 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-26 16:25:43.318 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Application Command Request (ALIVE:REQUEST_NIF)
2020-05-26 16:25:43.318 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-05-26 16:25:43.318 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: SECURITY not supported
2020-05-26 16:25:43.318 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 52: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2020-05-26 16:25:43.318 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 255
2020-05-26 16:25:43.318 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - Sensor Type is null
2020-05-26 16:25:43.318 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - NODE 52: Sensor Binary report, type=Unknown, value=255
2020-05-26 16:25:43.318 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-05-26 16:25:43.318 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
2020-05-26 16:25:43.318 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Updating channel state zwave:device:f18426fd:node52:sensor_binary to ON [OnOffType]
2020-05-26 16:25:43.319 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Commands processed 1.
2020-05-26 16:25:43.319 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@248faddf.
2020-05-26 16:25:43.319 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-26 16:25:43.319 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-26 16:25:43.319 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
Door sensor set to closed orientation:
2020-05-26 16:26:02.585 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 34 0B 71 05 00 00 00 FF 06 17 00 00 00 4F
2020-05-26 16:26:02.585 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 0B 71 05 00 00 00 FF 06 17 00 00 00
2020-05-26 16:26:02.585 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 0B 71 05 00 00 00 FF 06 17 00 00 00
2020-05-26 16:26:02.585 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-26 16:26:02.586 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Application Command Request (ALIVE:REQUEST_NIF)
2020-05-26 16:26:02.586 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-05-26 16:26:02.586 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: SECURITY not supported
2020-05-26 16:26:02.586 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 52: Received COMMAND_CLASS_ALARM V5 NOTIFICATION_REPORT
2020-05-26 16:26:02.586 [DEBUG] [ernal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 52: NOTIFICATION report - 0 = 0, event=23, status=255, plen=0
2020-05-26 16:26:02.586 [DEBUG] [ernal.protocol.commandclass.ZWaveAlarmCommandClass] - NODE 52: Alarm Type = ACCESS_CONTROL (0)
2020-05-26 16:26:02.586 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-05-26 16:26:02.586 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-05-26 16:26:02.586 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter processing NOTIFICATION
2020-05-26 16:26:02.586 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter NOTIFICATION event is 23, type OnOffType
2020-05-26 16:26:02.586 [DEBUG] [nding.zwave.internal.converter.ZWaveAlarmConverter] - NODE 52: Alarm converter NOTIFICATION event is 23, channel alarm_access is not implemented.
2020-05-26 16:26:02.586 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Commands processed 1.
2020-05-26 16:26:02.586 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@75f737df.
2020-05-26 16:26:02.587 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-26 16:26:02.587 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-05-26 16:26:02.587 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-05-26 16:26:02.601 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 34 04 30 03 00 FF 0D
2020-05-26 16:26:02.602 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 04 30 03 00 FF
2020-05-26 16:26:02.602 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=52, callback=0, payload=00 34 04 30 03 00 FF
2020-05-26 16:26:02.602 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-05-26 16:26:02.602 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Application Command Request (ALIVE:REQUEST_NIF)
2020-05-26 16:26:02.602 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-05-26 16:26:02.602 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 52: SECURITY not supported
2020-05-26 16:26:02.602 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 52: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2020-05-26 16:26:02.602 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 255
2020-05-26 16:26:02.602 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - Sensor Type is null
2020-05-26 16:26:02.602 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - NODE 52: Sensor Binary report, type=Unknown, value=0
2020-05-26 16:26:02.602 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-05-26 16:26:02.602 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
2020-05-26 16:26:02.603 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 52: Updating channel state zwave:device:f18426fd:node52:sensor_binary to OFF [OnOffType]
2020-05-26 16:26:02.603 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Commands processed 1.
2020-05-26 16:26:02.603 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 52: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d25c352.
2020-05-26 16:26:02.603 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-05-26 16:26:02.603 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
