Debugging
Hi everybody,
is there an easy way to debug or test some Terms?
I alway put an logInfo into a rule an fire the event.
But can i execute a logInfo Comamnd in a shorter way to see the result in the Log Viewer?
No. logInfo is an Action that can be run from a Rule. You have to run the Rule to execute the logInfo.
What are you trying to accomplish? What are you trying to log outside of a Rule?
I just want to see some values of different expressions.
do you know an easy way of executing a rule?
Create an Item and send it a command. Trigger the Rule when the Item receives a command.
