Hi all,
I’m using system info binding to get some infos about my CPU utilisation. This works perfect, only thing is that the average is in formar 0.x where the openhab utilisation is displayed as xx,0. (which makes the charts unreadable). I thought it would be easy to transform the value with a simple conversion rule like this:
Item:
Number loadAverage1min "Load avg. 1min [%.1f%%]" (Server) {systeminfo="LoadAverage1Min:50000:JS(mal100.js)" }
script:
(function(i){ return i * 100; })(input)
The value still remains the same - I’m transforming the temperature in the same way and it works…
How to apply this to the values from the system info binding?
Thanks for any help!
