I’d install the Multisensor Aqara WSDCGQ11LM Temperature Humidity Sensor like
https://www.gearbest.com/access-control/pp_626702.html?wid=1433363
in the deconz app successfull. In the app the value of the temperature, humidity, pressure and battery is correct.
In Openhab the bridge and the 2 temperature sensors are online as things. The value of the temperature in the items are x10 (4°C-> 400°C), but the things of the other sensors are not visible. There is also no (known) error thrown.
My thing-config :
Bridge deconz:deconz:homeserver [ host=“192.168.1.36:8080”, apikey=“1234567” ] {
temperaturesensor temperatur1 “Temperatur1” [ id=“2” ]
temperaturesensor temperatur2 “Temperatur2” [ id=“5” ]
humiditysensor feuchte1 “Humidity1” [ id=“3” ]
pressuresensor luftdruck2 “Pressure2” [ id=“7” ]
the items:
Number:Temperature Temperatur4ZB1 “Temperatur 1 [%.1f °C]” { channel=“deconz:temperaturesensor:homeserver:temperatur1:temperature” }
Number:Temperature Temperatur4ZB2 “Temperatur 2 [%.1f °C]” { channel=“deconz:temperaturesensor:homeserver:temperatur2:temperature” }
Number:Dimensionless Feuchte4ZB1 “Feuchte 1 [%.1f %%]” { channel=“deconz:humiditysensor:homeserver:feuchte1:humidity” }
Number:Pressure Luftdruck4ZB2 “Luftdruck 2 [%.1f hPa]” { channel=“deconz:pressuresensor:homeserver:luftdruck2:pressure” }
The number of the id’s of the temperature sensors I’d get from the deconz-webapp and the pressure and humidity from the deconz-App.
The Questions:
- supports the current deconz-binding multi-Sensors?
if yes: - why the humidity and pressure not online and
- where I can find the ID’s of the other sensors?
Sincerely
Jens
- Platform information:
- Hardware: Raspi 3 (1 Raspi for OH, 1 Raspi for deConz)
- OS: Debian 9
- openHAB version: 2.4
