i have problems with the deconz server since 2 weeks and I didn´t find the fault.
Does any one have an Idea for the problem?
I search in this forum but I don´t find the problem
If I restart the stystem all binding are in function.
After about 3-6 hours the deconz binding have a communication error.
With the communication error I can controll the lights, but I get a bad response.
So all rules are out of function.
On the deconz binding i have some window- and motionsensors and 5 hue lights.
In the eventlog I get these output:
2020-09-18 11:16:13.233 [hingStatusInfoChangedEvent] - ‘deconz:deconz:5fd26ce2’ changed from OFFLINE (COMMUNICATION_ERROR): org.eclipse.jetty.websocket.api.UpgradeException: 0 null to OFFLINE (COMMUNICATION_ERROR): 0 null
2020-09-18 11:16:13.244 [hingStatusInfoChangedEvent] - ‘deconz:deconz:5fd26ce2’ changed from OFFLINE (COMMUNICATION_ERROR): 0 null to OFFLINE (COMMUNICATION_ERROR): org.eclipse.jetty.websocket.api.UpgradeException: 0 null
And in the openhab.log I don´t have any output at this time
System
Raspberry Pi 4 with Openhab, Deconz (Port 80) and pvCCU3
2020-10-15 16:59:06.235 [DEBUG] [ernal.handler.DeconzBaseThingHandler] - Get new state failed:
java.util.concurrent.CompletionException: java.util.concurrent.TimeoutException: Total timeout 2000 ms elapsed
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:292) ~[?:1.8.0_262]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:308) ~[?:1.8.0_262]
at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:607) ~[?:1.8.0_262]
at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:591) ~[?:1.8.0_262]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:488) [?:1.8.0_262]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:1990) [?:1.8.0_262]
at org.openhab.binding.deconz.internal.netutils.AsyncHttpClient$1.onComplete(AsyncHttpClient.java:109) [bundleFile:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:198) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:190) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:444) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpReceiver.abort(HttpReceiver.java:527) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpChannel.abortResponse(HttpChannel.java:156) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpChannel.abort(HttpChannel.java:149) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpExchange.abort(HttpExchange.java:257) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpConversation.abort(HttpConversation.java:149) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpRequest.abort(HttpRequest.java:768) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.TimeoutCompleteListener.onTimeoutExpired(TimeoutCompleteListener.java:51) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.CyclicTimeout$Wakeup.run(CyclicTimeout.java:282) [bundleFile:9.4.20.v20190813]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_262]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_262]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_262]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_262]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_262]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_262]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_262]
Caused by: java.util.concurrent.TimeoutException: Total timeout 2000 ms elapsed
... 9 more
2020-10-15 16:59:06.248 [DEBUG] [ernal.handler.DeconzBaseThingHandler] - Get new state failed:
... 9 more
events.log:
2020-10-15 16:59:07.063 [hingStatusInfoChangedEvent] - 'deconz:deconz:xxxxxxxx' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Value must be between 0 and 100
2020-10-15 16:59:07.074 [hingStatusInfoChangedEvent] - 'deconz:colortemperaturelight:xxxxxxxx:00118d0008870cc0000' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
I´m sorry. In the last time i haven´t time for my smarthome.
I have the same error.
The Deconz and Openhab-Server are running on the same raspberry.
Sometimes the Deconz-Server goes offline after I turn the light off.
Blockquote
2020-11-02 18:18:08.663 [DEBUG] [nternal.netutils.WebSocketConnection] - Connect: /192.168.178.57
2020-11-02 18:18:08.653 [DEBUG] [nternal.netutils.WebSocketConnection] - Connecting to: ws://192.168.178.57:443
2020-11-02 18:18:08.669 [DEBUG] [nternal.netutils.WebSocketConnection] - Connecting to: ws://192.168.178.57:443
2020-11-02 18:18:08.674 [DEBUG] [nternal.netutils.WebSocketConnection] - Connecting to: ws://192.168.178.57:443
2020-11-02 18:18:08.674 [DEBUG] [nternal.netutils.WebSocketConnection] - Connect: /192.168.178.57
2020-11-02 18:18:08.683 [DEBUG] [nternal.netutils.WebSocketConnection] - Connect: /192.168.178.57
2020-11-02 18:18:08.690 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘236’, scaledValue = ‘93’
2020-11-02 18:18:08.691 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2020-11-02 18:18:08.696 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘236’, scaledValue = ‘93’
2020-11-02 18:18:08.698 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2020-11-02 18:18:08.708 [DEBUG] [nternal.netutils.WebSocketConnection] - Connect: /192.168.178.57
2020-11-02 18:18:08.717 [DEBUG] [nternal.netutils.WebSocketConnection] - Connecting to: ws://192.168.178.57:443
2020-11-02 18:18:08.725 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘140’, scaledValue = ‘56’
2020-11-02 18:18:08.724 [DEBUG] [nternal.netutils.WebSocketConnection] - Connect: /192.168.178.57
2020-11-02 18:18:08.726 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘11’, scaledValue = ‘5’
2020-11-02 18:18:09.326 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2020-11-02 18:18:09.940 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘236’, scaledValue = ‘93’
2020-11-02 18:18:09.941 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2020-11-02 18:18:09.946 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘236’, scaledValue = ‘93’
2020-11-02 18:18:09.947 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2020-11-02 18:18:10.034 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘140’, scaledValue = ‘56’
2020-11-02 18:18:10.035 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘11’, scaledValue = ‘5’
2020-11-02 18:18:10.140 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2020-11-02 18:18:10.693 [DEBUG] [ernal.handler.DeconzBaseThingHandler] - Get new state failed:
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:292) ~[?:1.8.0_212]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:308) ~[?:1.8.0_212]
at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:593) ~[?:1.8.0_212]
at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:577) ~[?:1.8.0_212]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:474) [?:1.8.0_212]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:1977) [?:1.8.0_212]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_212]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_212]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_212]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_212]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_212]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_212]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
… 9 more
event.log
Blockquote
2020-11-02 18:18:08.872 [hingStatusInfoChangedEvent] - ‘deconz:deconz:5fd26ce2’ changed from OFFLINE (COMMUNICATION_ERROR): Disconnected to OFFLINE (COMMUNICATION_ERROR): Value must be between 0 and 100
2020-11-02 18:18:08.874 [hingStatusInfoChangedEvent] - ‘deconz:colortemperaturelight:5fd26ce2:001788010204ef830b’ changed from OFFLINE (GONE): Not reachable to OFFLINE (BRIDGE_OFFLINE)
2020-11-02 18:18:08.875 [hingStatusInfoChangedEvent] - ‘deconz:extendedcolorlight:5fd26ce2:0017880104d968bc0b’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-11-02 18:18:08.888 [hingStatusInfoChangedEvent] - ‘deconz:batterysensor:5fd26ce2:680ae2fffeec4616010001’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
Unfortunately all of these message don’t put a complete picture of what is happening and why the re-connect does not happen. Please set binding to TRACE logging.
And check if you selected the correct item-type for each channel (escpecially the color-temperature channel). The Value must be between 0-100 message indicates that there might be a problem.
@Snupru@J-N-K Where can I get this version? I have the 2.5.10 and some errors, so before I open a git issue i would like to check it with the newest version
Which item-type do you choosed for colortemperature and color-values? I have a similar problem…
Colortempetature is Number and Color is Color? 2021-02-28 19:01:07.776 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘243’, scaledValue = ‘96’
2021-02-28 19:01:07.780 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2021-02-28 19:01:08.836 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘243’, scaledValue = ‘96’
2021-02-28 19:01:08.838 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2021-02-28 19:01:10.771 [DEBUG] [z.internal.handler.LightThingHandler] - Sending command 19,96,100 to channel deconz:extendedcolorlight:b5f7dc6c:00158d0005018a5801:color failed:
java.util.concurrent.CompletionException: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:331) ~[?:?]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:346) ~[?:?]
at java.util.concurrent.CompletableFuture$UniAccept.tryFire(CompletableFuture.java:704) ~[?:?]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:506) [?:?]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:2088) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.util.concurrent.TimeoutException: Total timeout 3000 ms elapsed
… 8 more
