I just added few water leak sensor to my conbee II. Everything went fine. It appear on the phoscon webapp
With all the information, correctly updated
Even in the api, everything look good
Then I’ve added things to my openhab conf
Thing deconz:openclosesensor:deconz_bridge:watersensor_01 "Water sensor 1" (deconz:deconz:deconz_bridge) @ "Maison" [ uid="00:15:8d:00:06:c2:41:e8-01-0500", id="97" ]
Thing deconz:openclosesensor:deconz_bridge:watersensor_02 "Water sensor 2" (deconz:deconz:deconz_bridge) @ "Maison" [ uid="00:15:8d:00:06:c5:d5:6f-01-0500", id="98" ]
Thing deconz:openclosesensor:deconz_bridge:watersensor_03 "Water sensor 3" (deconz:deconz:deconz_bridge) @ "Maison" [ uid="00:15:8d:00:06:c2:50:93-01-0500", id="99" ]
Thing deconz:openclosesensor:deconz_bridge:watersensor_04 "Water sensor 4" (deconz:deconz:deconz_bridge) @ "Maison" [ uid="00:15:8d:00:06:c4:d1:a0-01-0500", id="100" ]
Then items
Contact WaterSensor_1_Open "Open/close" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:open"}
DateTime WaterSensor_1_LastUpdated "Last updated" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:last_updated"}
Number WaterSensor_1_BatteryLevel "Niveau de la batterie" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:battery_level"}
Switch WaterSensor_1_BatteryLow "Batterie faible" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:battery_low"}
Number:Temperature WaterSensor_1_Temperature "Temperature" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:temperature"}
Switch WaterSensor_1_Tampered "Tampered" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:tampered"}
DateTime WaterSensor_1_LastSeen "Last seen" {channel="deconz:openclosesensor:deconz_bridge:watersensor_01:last_seen"}
And sadly… Only the Tempered and LastUpdated propeties get updated. All the other one stay at null.
I’ve created the item using the OpenHab addon in VSCode
Did I do something wrong or is this binding missing an information?
Thanks a lot
