Deconz Binding: Xiaomi Motion Sensor
I successfully connected a Xiaomi Motion Sensor to my openhab setup, but still have one question:
I implemented the sensor manually to my items file like this:
Switch	Alarm_PIR1	"Alarm1 [%s]"	<motion>	(FF_Wg)		{ channel="deconz:presencesensor:homeserver:PIR1:presence" }
I also added a update item:
ateTime Alarm_PIR1_Update "letzte Bewegung: [%1$td.%1$tm.%1$ty %1$tH:%1$tM]" <clock> (FF_Wg) { channel="deconz:presencesensor:homeserver:PIR1:last_updated"}
Unfortunately the first item always show “ON” and is not turning OFF, but I see the sensor is working correctly because hte Update stamp is updating when movement is detected.
So any idea what I have done wrong with my first item?
Thanks in advance
edit: I realised it indeed turns from ON to OFF, but it take 90 seconds to do so. Is there a way to reduce the interval?
