deCONZ (GONE) strange behavior OH3-RP4
Hello there,
##    Uptime = 0 day(s). 0:27:24
## CPU Usage = 4.26% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
##  CPU Load = 1m: 1.58, 5m: 1.31, 15m: 0.92
##    Memory = Free: 2.45GB (65%), Used: 1.34GB (35%), Total: 3.79GB
##      Swap = Free: 2.99GB (100%), Used: 0.00GB (0%), Total: 2.99GB
##      Root = Free: 107.73GB (95%), Used: 4.56GB (5%), Total: 117.09GB
##   Updates = 0 apt updates available.
##  Sessions = 1 session(s)
## Processes = 136 running processes of 32768 maximum processes
openHAB 3.2.0 - Release Build
I did a manually fresh install of openhabian.
I’ve switched from my old RPI3+ to my ā€œnewā€ RPI4 with SSD.
Now I stand before an problem, which I can’t fix myself. (google doesn’t help)
I’ve running deCONZ with a CONBEE II and got some AQARA humidity sensors.
If I start the Raspberry4 ALWAYS the device(thing) is turning to ā€œGONEā€.
Anyways how often I restart the Raspberry, the devices(thing) will always receive gone.
BUT, if I disable and enable the item again, the status is turning to ā€œonlineā€ which seems good.
very strange, I thought the status will be switch from gone to online, if the item receives an update.
It is receiving an update through the openhab logger (:9001) and STILL standing on gone ?
How is that possible ?
Some log entry:
startup and receiving gone:
2022-04-28 09:40:56.483 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E060A32' changed from UNINITIALIZED to INITIALIZING
2022-04-28 09:40:56.566 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2022-04-28 09:40:56.584 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2022-04-28 09:41:06.705 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:deconz:00212E060A32' changed from INITIALIZING to ONLINE
2022-04-28 09:41:06.709 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2022-04-28 09:41:06.712 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2022-04-28 09:41:06.744 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from INITIALIZING to UNKNOWN
2022-04-28 09:41:06.747 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from INITIALIZING to UNKNOWN
2022-04-28 09:41:06.750 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from UNKNOWN to OFFLINE (GONE): Not reachable
2022-04-28 09:41:06.753 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from UNKNOWN to OFFLINE (GONE): Not reachable
log entry from the update and STILL ā€œgoneā€:
2022-04-28 09:40:45.603 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroSensorLUMI_Humidity' changed from NULL to 60.42 %
2022-04-28 09:40:47.650 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroSensorLUMI_Temperature' changed from NULL to 20.39 °C
2022-04-28 09:40:48.649 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TasmotaLEDLampeBuro_ANAUS' changed from NULL to OFF
2022-04-28 09:44:48.537 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroSensorLUMI_Temperature' changed from 20.39 °C to 20.48 °C
2022-04-28 09:44:48.540 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroSensorLUMI_Humidity' changed from 60.42 % to 59.730000000000004 %
2022-04-28 09:47:54.821 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroSensorLUMI_Temperature' changed from 20.48 °C to 20.53 °C
2022-04-28 09:47:54.824 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BuroSensorLUMI_Humidity' changed from 59.730000000000004 % to 60 %
and log entry of disable / enable → turning to online:
2022-04-28 09:48:41.498 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from OFFLINE (GONE): Not reachable to UNINITIALIZED
2022-04-28 09:48:41.565 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-04-28 09:48:48.679 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from OFFLINE (GONE): Not reachable to UNINITIALIZED
2022-04-28 09:48:48.705 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-04-28 09:48:51.510 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-04-28 09:48:51.530 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from INITIALIZING to UNKNOWN
2022-04-28 09:48:51.571 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:humiditysensor:00212E060A32:00158d000549b6d3010405' changed from UNKNOWN to ONLINE
2022-04-28 09:48:54.829 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-04-28 09:48:54.852 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from INITIALIZING to UNKNOWN
2022-04-28 09:48:54.887 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'deconz:temperaturesensor:00212E060A32:00158d000549b6d3010402' changed from UNKNOWN to ONLINE
I hope someone can give me a hint or help me with this case.
Thanks =)
Greetings
Kahzia
I did a small fix for this in 3.3:
It only removes GONE, so devices are still marked as OFFLINE with the reason of being unreachable.
Best regards,
Jacob Laursen
thanks for that information.
I’ve installed the latest 3.3 Milestone.
As you say, it only removes the ā€œgoneā€ and replace it with ā€œofflineā€.
So there is no chance that it will automatically turn to ā€œonlineā€ ?
If I had to do an restart, I will need to disable and enable all devices correct ?
Why does it only occur for me with a RPI4 ?
Greetings
Kahzia
EDIT:
okay, now its always marked as offline, disable and enable doesn’t work with the 3.3.
So it stays as offline but the item can still receive updated values…
