Hi folks,
I’m trying to provision my OH3 with deconz binding using the things file. I read the docs and observe created my deconz.things
(deconz is running the latest stable version on a host deconz
and port 9080
reachable from the openhab installation.
Bridge deconz:deconz:deconz "deCONZ Gateway" [ host="deconz", httpPort="9080", apiKey="SOMEKEY" ] {
// Actors
dimmablelight 14-xxx-3601 "Arbeitslicht Kinderzimmer" @ "Kinderzimmer 1.OG" [ id="2" ]
My problem is that the API key seems to be lost every time. Here is what I observe:
If I provide no key, the binding reports config pending and waits until I enable 3-rd party authentication inside the app. After doing this, the pairing is completed, the binding is connected to the gateway, I can do anything as expected. The configuration property of the bridge shows the exchanged key. Going to OH-CLI shows the same key there.
Now if I copy this key into my things file and restart openhab the following happens:
The binding still shows config pending. The configuration parameter in the UI is not showing the key, but the OH CLI does. If I take this key and connect using a REST cliekt, I can access to any resources provided by the REST API - so the keys to be valid. For some reason the binding is not taking it into consideration. I can still resolve this by activating 3-rd party pairing in the gateway, but this will generate a new API key.
To make it clear - the binding works without problems, once paired with the gateway manually, but is locked in configuration pending
after ever restart. Any ideas?
Cheers,
Simon
