after I set up my rapberry with openhabian and got my deconz USB stick working I thought it might be a good idea to setup a textual configuration for my system. So far everything is working but I just don’t get any “things” into openhab from the *.things file. To be honest I don’t have any idea, where this [ID] in the deconz demo comes from. I don’t see it in the deconz web page with all my lights listed.
Current state:
deconz binding via text
deconz bridge via text including API key
All items list in the inbox
Thats the basic information that I get from Paper UI “Things”
You api key is the same as the password you obtained to connect the hue bridge or deconz.
Sorry, I don’t have a short answer process off the top of my head as it has been some time since I did it. There is documentation on accessing the api in the openHAB binding doc I believe. But for sure in the deconz rest api docs.
The best I can give off the top of my head is this you obtain an api key by going to the deconz api link. Once you have that key you are able to go to http://deconzip/api/lights and get each bulbs id.
Then you go to a link like: http://192.168.107.20:8090/api/api-key/sensors . Replace sensors with lights for lights. Note: my deconz runs on port 8090, if yours is different change that property also.
