Hi, is it possible to set expiration timer in a .items file?
I want to do the same thing that I was able to do using the UI, but in my .items definition file:
Thanks!
so it should be like that:
Switch MyItem "My Expiration Timer" {channel="...",expire="30m,OFF"}
IF you need a command (that is: a binding should send the OFF command to some hardware), you’ll need to add command=
to the configuration:
Switch MyItem "My Expiration Timer" {channel="...",expire="30m,command=OFF"}
