I am wondering how I can define constant in rules/lambdas, instead of having to redeclare them every time i change the lights?
var HSBType hsbValue
var HSBType hsbValueMasterBedRoom
var HSBType hsbValueBathRoom
val hsbOff = HSBType::fromRGB(0, 0, 0)
val hsbOn = HSBType::fromRGB(255, 255, 255)
var boolean partyMode
var int redColor
var int greenColor
var int blueColor
var DecimalType dimmer_MasterBedRoom_Value
var int redValue
var int greenValue
var int blueValue
var String RGBvalues
////////////// Switch the different areas where LED-Lights should be switched on/off ////////////////7////////////
val Functions.Function3 rgbLights= [ GroupItem mainGroup,GroupItem subGroup, HSBType hsbValueIn |
mainGroup.members.filter[l|l.state.toString != hsbOff.toString].forEach[l| l.sendCommand(hsbOff.toString()) ]
subGroup.members.forEach[l2|l2.sendCommand(hsbValueIn)]
however if I comment out val hsbOff = HSBType::fromRGB(0, 0, 0)
I get this error:
2017-09-19 21:02:27.227 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Activate Scene LivingRoom': cannot invoke method public java.lang.String org.eclipse.smarthome.core.library.types.HSBType.toString() on null
