Hello
I program a lot of Arduino’s but i am a newbie in openhab.
I use the latest openhab version with following Hardware:
Raspberry Pi 3B+
8 x MCP23017 (4 as input, 4 as output)
Connected with the horter&kalb i2c-repeater (5V logic transmitter to the 3,3v Raspberry)
The wireing are correct (Reset Pin, Adresses…)
At the beginning i use fhem. Here i use the interrupt of the MCPs to read out the states of the MCPs.
Everything is working there. But fhem is not my favorite software
The “orginal” Binding does not work correctly, because after booting the MCP ICs does not responding.
Now i use the binding “org.openhab.binding.mcp23017-2.4.0-SNAPSHOP.jar”
After booting the all MCPs work fine.
But, an few hours later the inputs have a delay. I thought the i2c goes in a sleep mode and so i make a timer every 5 minutes for one output (5 Seconds on, 5 minutes out).
But that does not work either. Have anyone a idea what can i do?
