Vincent
(Vincent)
June 8, 2016, 9:18am
#1
In v 1.8.3 I get the following error message while using the demo.rules
On the line
postUpdate(Weather_Temp_Max, Weather_Temperature.maximumSince(now.toDateMidnight).state)
I get the error message
Couldn’t resolve reference to JvmIdentifiableElement ‘now’.
Couldn’t resolve reference to JvmIdentifiableElement ‘toDateMidnight’.
However the date is correct : when logging
now.toDateMidnight
I get the result
2016-06-08T00:00:00.000+02:00
Does anyone nows where this comes from?
rlkoshak
(Rich Koshak)
June 8, 2016, 7:02pm
#2
Are you referring to errors in Designer when you say you “get the error message” or are you seeing this in the log?
If Designer, what version of Designer are you using?
Vincent
(Vincent)
June 9, 2016, 6:54am
#3
This is an error indicated in the designer.
It appears when changing the file.
To be sure, I reinstalled the latest version 1.8.3.
I verified, and the error is appearing.
rlkoshak
(Rich Koshak)
June 9, 2016, 2:22pm
#4
Well something is up with Designer but it works while running so the problem lies in Designer. I’m not sure what could be causing this as access to now is fundamental and has been there forever.
