I’m wondering how to change the state of the lights in my living room depending on what input the avr is set to. I already have the Denon binding and hue binding running ok, I just can’t work out how to write a rule for what I want.
rule "Denon change lights"
Item DenonAVR_Input changed // Item linked to the input channel of your denon thing
if (triggeringItem.state == "HDMI1") { // For example, I don't know what the names of the inputs are
myLamp1.sendCommand(ON)
myLamp2.sendCommand(OFF)
myLamp3.sendCommand(50)
That works perfectly thanks! Although when I ask it to put the dimmer back up to 100% it changes the colour too nevermind.
Another thing I’m failing to do is set a timer, I want the input to change on the avr then a timer start before the lights dim/turn off. The code is coming back with no errors but still does not work.
