just upgraded to 1.7.1, binding 1.7.1, here the log appeared:
2015-10-03 21:44:41.707 [WARN ] [.denon.internal.DenonConnector] - Encoding error in get
javax.xml.bind.UnmarshalException: null
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.handleStreamException(UnmarshallerImpl.java:468) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:402) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:371) ~[na:1.8.0_31]
at org.openhab.binding.denon.internal.DenonConnector.getDocument(DenonConnector.java:549) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.setConfigProperties(DenonConnector.java:474) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.getInitialState(DenonConnector.java:189) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.connect(DenonConnector.java:147) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonBinding.updated(DenonBinding.java:189) [bundlefile:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:183) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
Caused by: com.sun.istack.internal.SAXParseException2: unexpected element (uri:"", local:“html”). Expected elements are <{}device_Info>
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext.handleEvent(UnmarshallingContext.java:726) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.Loader.reportError(Loader.java:247) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.Loader.reportError(Loader.java:242) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.Loader.reportUnexpectedChildElement(Loader.java:109) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext$DefaultRootLoader.childElement(UnmarshallingContext.java:1131) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext._startElement(UnmarshallingContext.java:556) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallingContext.startElement(UnmarshallingContext.java:538) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.InterningXmlVisitor.startElement(InterningXmlVisitor.java:60) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.StAXStreamConnector.handleStartElement(StAXStreamConnector.java:231) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.StAXStreamConnector.bridge(StAXStreamConnector.java:165) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:400) ~[na:1.8.0_31]
… 8 common frames omitted
Caused by: javax.xml.bind.UnmarshalException: unexpected element (uri:"", local:“html”). Expected elements are <{}device_Info>
… 19 common frames omitted
2015-10-03 21:44:43.159 [INFO ] [.myopenhab.internal.MyOHClient] - Connected to my.openHAB service
2015-10-03 21:44:44.046 [WARN ] [.denon.internal.DenonConnector] - Encoding error in post
javax.xml.bind.UnmarshalException: unexpected element (uri:"", local:“html”). Expected elements are <{}cmd>,<{}rx>,<{}text>
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.SAXConnector.startElement(SAXConnector.java:153) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:379) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(XMLNSDocumentScannerImpl.java:605) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3138) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:880) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:117) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213) ~[na:1.8.0_31]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:243) ~[na:1.8.0_31]
at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:214) ~[na:1.8.0_31]
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:157) ~[na:1.8.0_31]
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:204) ~[na:1.8.0_31]
at org.openhab.binding.denon.internal.DenonConnector.postDocument(DenonConnector.java:573) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.updateDisplayInfo(DenonConnector.java:460) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.refreshHttpProperties(DenonConnector.java:496) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.updateState(DenonConnector.java:199) [bundlefile:na]
at org.openhab.binding.denon.internal.DenonConnector.getInitialState(DenonConnector.java:190) [bundlefile:na]
Any clue?
AVR 3311 here, trying using telnet. Will investigate also with http
2015-10-03 22:41:34.863 [WARN ] [.denon.internal.DenonConnector] - Encoding error in get
2015-10-03 22:41:35.077 [WARN ] [.denon.internal.DenonConnector] - Encoding error in post
Hi Andrea,
I use also the Denon Binding for controlling my Marantz SR 7005. It works well.
However, I experienced the same issues as you descriped and posted this in https://groups.google.com/forum/#!msg/openhab/bSTEfSRt0RU/rOI6uWUe7bIJ (I believe you have seen this).
It seems that certain xml files are not defined.
Unfortunately I am not an experienced programmer, but if I can be of any help …
Cheers
Björn
