I am trying out OH2. Several bindings automatically discover devices in Paper UI. Could this feature be added to the Denon binding?
Only if there is a 2.0 Denon Binding, which I am not aware of.
If the reason you’re asking is because you aren’t sure of your Denon IP address, then you can use apps like Lanscan (Mac) or Advanced IP Scanner (Win) to scan your network and find it out. Then you can configure the config settings the same as in OH1 and it’ll work fine.
do i understand correct, i have the same item definition in OH2 as has been in OH1 ?
