@David_Graeff we´ve just had a topic on binding dependencies and jar files. You´ve mentioned the kar files.
I´ve seen that the maven karaf plugin can do remote deployments to a karaf instance. But only if kar files are used…
Do you know if I can change the packaging of my binding to kar and do remote deployment. (Sounds like a quite cool feature and a much better development workflow/experience).
If you run Karaf locally and you would like to have hotdeploy then its sufficient to run inside Karaf bundle:watch <binding-bundle-id> or simply watch * if you have bunch of things built within single maven execution.
Karaf watches the local maven repository (usually in $HOME/.m2 on all operating systems). And Eclipse can be instructed to install a bundle to the local maven repo whenever you click “Debug”. (I think that’s even the default for maven in Eclipse?!)
Indeed - you need to install bundle into local maven repository. There are various ways - ie run as > maven build > mvn install. You can also build new snapshot via command line.
