Expire has been merged into the core. So you configure it the same as it always has but you don’t have to install a separate binding to use it.
If that’s all you need then I recommend configuring the Expire Item metadata on the switch.
Any examples of rules that you see will still work in OH 2.5 with minor changes (usually to do with changing the date time classes or executeCommandLine). So pretty much everything in the original post will work as is. To use the Python code you’ll need to install the Python add-on and the Helper Libraries for OH 3.
That looks OK. How did you test it? As configured, when the Item changes or updates to any state other than OFF, two minutes later Expire will send an OFF command to the Item. If you didn’t change or update the Item after setting the metadata nothing will happen. There has to be an event to start the timer.
You might want to think about what effect you are expecting. Sending an OFF command to the sensor is not likely to do much?
If you want lights to turn off after a period, it is the light that needs the expire.
If I wave in front of sensor, I got Item 'PIRVchod_MotionStatus' changed from OFF to ON
after one minute the binding is expired, I got this:
2021-02-09 20:09:21.184 [ERROR] [al.handler.XiaomiSensorMotionHandler] - Channel mihome:sensor_motion_aq2:286c0785f092:158d00016dacaf:motion does not exist
2021-02-09 20:09:21.172 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'PIRVchod_MotionStatus' received command OFF
2021-02-09 20:09:21.181 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'PIRVchod_MotionStatus' predicted to become OFF
2021-02-09 20:09:21.187 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PIRVchod_MotionStatus' changed from ON to OFF
The rule is simply not working - the plug is not switched on, but I cant even see, if the rule was activated.
Given the events.log above, the rule didn’t trigger because it didn’t update to ON. You’ve written the rule to only run when that happens.
Add logging to the rule to see if it was activated. Or bring up the developer sidebar and start the event stream. You’ll see an event when the rule triggers
I have added some logging to my command like this:
rule "Motion sensor triggered"
Item PIRVchod_MotionStatus received update ON
logInfo("rule running", "Rule Motion running")
BWSHP63_state.sendCommand(ON)
Looks like there is no more error on Binding expiration, but I cant see that the Rule has been catched.
Hmmm…
If you are not using .rules files and instead are defining the rule in the UI, you are using the completely wrong syntax. You create the Rule and configure the trigger separately. For the then choose Script Action and choose Rules DSL as the language and put
It depends on the rest of your requirements but I’d recommend using the Open Door Reminder rule template on the marketplace (link in the OP). Why write code if you don’t have to?
Beyond that, any of the approaches discussed above should work, just not necessarily the code examples. You might need to translate to more modern ways of doing things. But the approach remains to set a timer, reschedule it on subsequent events, do something when the timer expires.
Went the route you suggested. I think I assumed that approach was deprecated since this post has [Deprecated] in the title, but that’s probably just a bad assumption on my part.
I followed the steps above, all seemed ok, but the rule didn’t seem to be working. Check my logs and saw this
2023-03-27 21:06:30.931 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘garageLightsOffAfterTime’ failed: org.graalvm.polyglot.PolyglotException: TypeError: Cannot load CommonJS module: ‘openhab_rules_tools’
2023-03-27 21:06:30.940 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
at com.oracle.truffle.polyglot.PolyglotMapAndFunction.apply(PolyglotMapAndFunction.java:46) ~[?:?]
at org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine.lambda$7(OpenhabGraalJSScriptEngine.java:216) ~[?:?]
at java.util.Optional.orElseGet(Optional.java:369) ~[?:?]
at org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine.lambda$5(OpenhabGraalJSScriptEngine.java:216) ~[?:?]
at .:program(:1) ~[?:?]
at org.graalvm.polyglot.Context.eval(Context.java:399) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[java.scripting:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:53) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:74) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:71) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:68) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1180) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:989) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Saw a few threads on the error but nothing recent. I’m running OH 3.4.2
I have a rule that turns on an item that has the expire set to the time I want when motion is detected.
I have the motion detector device timeout set to 10 seconds so every time there is movement it sends an ON to the item with the expire and this resets the item timeout.
You can use real item switches or virtual item switches.
Yes I know I am using the expire for uses it wasn’t intended but it works well. I have been using it this way for over a year or so.
Pay attention to the prequisites. Did you install the openhab_rukes_tools library? If you are on openHABian there ya an option to do so in openhabian-config.
