You are right, I posted it to the script action. I deleted the old rule and recreated it like you said. It works now. But when I run it I am getting the following error:
Default_Morning has undefined which is not a valid day type, expected one of default,weekday,weekend,dayset,holiday,custom.
This is the meta data I have in Default_Morning:
Value: MORNING
Config: {}
I tried to put in:
type= default
but it disappears every time I put it in.
Sorry, I didnāt realize that was so important. I thought you accidentally indented it or something.
It starting working with no errors after I made that change. Hey, one more thing. I used the Time of Day Rule to update to update my Morning and Bed Time. Both of these are fixed times. When I look at the item in OpenHAB3 they both show the year as 1970. Is that OK? It really shouldnāt affect anything, I donāt think.
Thanks for your help.
Yes. When the Time of Day rule runs it will forward any of the Items that have a Date prior to today to today.
Iāve seen it done well (YAML, Python, etc) and Iāve seen it done really badly (TCL/TK or what we used to call it Fickle TK). Every language has itās good parts and itās bad parts. I personally like the way YAML is structured compared to alternatives like JSON and XML when it comes to being easy for a human to read and understand. Instead of using tags or brackets, YAML uses indentation. And thatās something that the āpretty printersā for JSON and XML will add too. So why have opening and closing tags or symbols and indentation when you can express the same thing with just the indentation?
A lot of programming languages use indentation (tabs, not spaces) mostly for human readability, youāre right, the code works fine without. YAML uses them as functional parameters, I see that. But Iāve far more often hunted for errors because of that (yaml configuration files, for instance) than otherwise. With brackets, itās a lot easier to see which parts of the code actually belong together, especially when that code stretches over many lines. But thatās just me. I guess with yaml you then have to count spaces
And JSON, well, I love it for parsing JSON outputs, but not for much more.
as i still struggle with my Openhab 3.0 Upgrade, one function needs a rewrite.
Currently i get a
āfailed: āgetHourOfDayā is not a member of ājava.time.ZonedDateTimeā; line 16, column 19, length 18 in icloudā
What i am doing?
Something like that:
var Number hour = now.getHourOfDay()
if (hour>=6 && hour<=9) {
sendCommand(Hue_Nachtmodus_Sensor_SensorState,"0")
So nothing special, just get the current hour and compare it to my timeframe.
This now fails.
Can anyone write me a quick and dirty example how to get the current hour in openhab3.0?
I have read through many threads, but i cannot imagine, that i have to perform such complex coding as mentioned just for getting the hour
It is already. There is a JavaScript UI generated rule linked to in the original post. Iām probably going to remove the Rules DSL version as I do not intend to continue supporting it for Time of Day. I never liked how it had to be implemented in Rules DSL and am not inclined to keep maintaining it any longer. My time is better spent elsewhere, especially since there is a Python version for OH 2.5 and a JavaScript version for OH 3 that will let you implement Time of Day without ever needing to look at or edit the code, and they let you define a different set of times of day based on the type of day.
In short, there are far better and more capable implementations of Time of Day posted and described in the original post. Use those instead.
val logName = "Time Of Day"
rule "Calculate time of day state"
System started or // run at system start in case the time changed when OH was offline
Channel 'astro:sun:home:rise#event' triggered START or
Channel 'astro:sun:home:set#event' triggered START or
Channel 'astro:sun:minus90:set#event' triggered START or
Time cron "0 1 0 * * ? *" or // one minute after midnight so give Astro time to calculate the new day's times
Time cron "0 0 6 * * ? *" or
Time cron "0 0 23 * * ? *"
logInfo(logName, "Calculating time of day...")
val ZonedDateTime zdt = ZonedDateTime.now()
val ZonedDateTime start_of_day = zdt.toLocalDate().atStartOfDay(zdt.getOffset())
// Calculate the times for the static tods and populate the associated Items
// Update when changing static times
// Jump to tomorrow and subtract to avoid problems at the change over to/from DST
val morning_start = start_of_day.plusDays(1).minusHours(18)
vMorning_Time.postUpdate(morning_start.toString)
val night_start = start_of_day.plusDays(1).minusHours(1)
vNight_Time.postUpdate(night_start.toString)
val bed_start = start_of_day
vBed_Time.postUpdate(bed_start.toString)
// Convert the Astro Items to Joda DateTime
val day_start = (vSunrise_Time.state as DateTimeType).getZonedDateTime()
val evening_start = (vSunset_Time.state as DateTimeType).getZonedDateTime()
val afternoon_start = (vEvening_Time.state as DateTimeType).getZonedDateTime()
// Calculate the current time of day
var curr = "UNKNOWN"
switch now {
case now.isAfter(morning_start) && now.isBefore(day_start): curr = "MORNING"
case now.isAfter(day_start) && now.isBefore(afternoon_start): curr = "DAY"
case now.isAfter(afternoon_start) && now.isBefore(evening_start): curr = "AFTERNOON"
case now.isAfter(evening_start) && now.isBefore(night_start): curr = "EVENING"
case now.isAfter(night_start): curr = "NIGHT"
case now.isAfter(bed_start) && now.isBefore(morning_start): curr = "BED"
// Publish the current state
logInfo(logName, "Calculated time of day is " + curr)
vTimeOfDay.sendCommand(curr)
// Examples for use of vTimeOfDay
rule "Day time started"
Item vTimeOfDay changed to "DAY" // does not work prior to OH 2.3 Release
// do stuff when DAY starts
Is this still true in the Javascript version?
I canāt check it now because of time of the year, but based on viewing the code, I get the feeling that it wonāt look anymore to the state (MORNING,DAY,EVENING etc), but just which comes first based on time. So in Summer if I set my MORNING to 07:00h and DAY to the sunrise (eg 06:13h), the sequence of events will be DAY, MORNING, EVENING etc.
Is this intentionally changed versus the old DSL rule?
I have to admit that I currently also rely on the DSL rule. The JS rule works fine, but every time I restart OH3 it messes up the ephemeris settings and that obviously kills the JS rule.
I donāt know that Iāve explicitly tested for it.
The JavaScript and Python versions do work differently by design so they might not work that way any more. Frankly, what I would do to handle this case is to adjust it in the Astro binding Thing where you can set a no-earlier than and no-later than properties to control when the times/events occur.
The Python and JavaScript versions of the rule are a complete rewrite and have almost nothing in common with the Rules DSL version.
Rules DSL
JavaScript/Python
Rule triggers at each time of day transition
Rule triggers once a day and sets timers for time of day transitions
Only works with Astro and cron times
Supports any DateTime Item
Has a fixed set of times of day
Supports a different set of times of day based on Ephemeris day type
Requires the rule code to be edited to change times of day
Only requires creation and editing of Items to change times of day
In my opinion, the JavaScript/Python versions are significantly better and more flexible compared to the Rules DSL version and Iām inclined to deprecate the Rules DSL version entirely.
