Ok, i checked it at one of the items and the custom meta data was avaible:
value: BED
type: custom
file: /openhab/conf/services/custom1.xml
I created this path now comming from root directory and copied custom1.xml to it.
Now i get a warning instead of an error:
19:37:18.730 [WARN ] [de.jollyday.util.ClassLoadingUtil ] - Could not load class with current threads context classloader. Using default. Reason: ClassNotFoundException: de.jollyday.impl.DefaultHolidayManager cannot be found by org.apache.aries.jax.rs.whiteboard_1.0.9
19:37:18.734 [WARN ] [de.jollyday.util.ClassLoadingUtil ] - Could not load class with current threads context classloader. Using default. Reason: ClassNotFoundException: de.jollyday.datasource.impl.XmlFileDataSource cannot be found by org.apache.aries.jax.rs.whiteboard_1.0.9
19:37:18.744 [WARN ] [de.jollyday.util.XMLUtil ] - Could not create JAXB context using the current threads context classloader. Falling back to ObjectFactory class classloader.
19:37:18.782 [WARN ] [re.automation.internal.RuleEngineImpl] - Fail to execute action: 3
java.lang.IllegalStateException: Cannot instantiate configuration from URL 'file:/openhab/conf/services/custom1.xml'.
at de.jollyday.datasource.impl.XmlFileDataSource.getConfiguration(XmlFileDataSource.java:43) ~[?:?]
at de.jollyday.impl.DefaultHolidayManager.doInit(DefaultHolidayManager.java:209) ~[?:?]
at de.jollyday.HolidayManager.init(HolidayManager.java:319) ~[?:?]
at de.jollyday.caching.HolidayManagerValueHandler.createValue(HolidayManagerValueHandler.java:44) ~[?:?]
at de.jollyday.caching.HolidayManagerValueHandler.createValue(HolidayManagerValueHandler.java:13) ~[?:?]
at de.jollyday.util.Cache.lambda$get$0(Cache.java:43) ~[?:?]
at java.util.concurrent.ConcurrentHashMap.computeIfAbsent(ConcurrentHashMap.java:1705) ~[?:?]
at de.jollyday.util.Cache.get(Cache.java:43) ~[?:?]
at de.jollyday.HolidayManager.createManager(HolidayManager.java:166) ~[?:?]
at de.jollyday.HolidayManager.getInstance(HolidayManager.java:146) ~[?:?]
at org.openhab.core.ephemeris.internal.EphemerisManagerImpl.getHolidayManager(EphemerisManagerImpl.java:235) ~[?:?]
at org.openhab.core.ephemeris.internal.EphemerisManagerImpl.isBankHoliday(EphemerisManagerImpl.java:284) ~[?:?]
at org.openhab.core.ephemeris.internal.EphemerisManagerImpl.isBankHoliday(EphemerisManagerImpl.java:289) ~[?:?]
at org.openhab.core.model.script.actions.Ephemeris.isBankHoliday(Ephemeris.java:91) ~[?:?]
at org.openhab.core.model.script.actions.Ephemeris.isBankHoliday(Ephemeris.java:85) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$108$5426A$\^eval\_.getTodayItems#custom(<eval>:124) ~[?:?]
at jdk.nashorn.javaadapters.java_util_function_Predicate.test(Unknown Source) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:176) ~[?:?]
at java.util.Iterator.forEachRemaining(Iterator.java:133) ~[?:?]
at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:550) ~[?:?]
at java.util.stream.AbstractPipeline.evaluateToArrayNode(AbstractPipeline.java:260) ~[?:?]
at java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:517) ~[?:?]
at java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:523) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$109$4398A$\^eval\_.getTodayItems(<eval>:121) ~[?:?]
at jdk.nashorn.internal.scripts.Script$Recompilation$128$\^eval\_.:program(<eval>:260) ~[?:?]
at jdk.nashorn.internal.runtime.ScriptFunctionData.invoke(ScriptFunctionData.java:655) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptFunction.invoke(ScriptFunction.java:513) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.internal.runtime.ScriptRuntime.apply(ScriptRuntime.java:527) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:456) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:413) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.evalImpl(NashornScriptEngine.java:409) ~[jdk.scripting.nashorn:?]
at jdk.nashorn.api.scripting.NashornScriptEngine.eval(NashornScriptEngine.java:162) ~[jdk.scripting.nashorn:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[java.scripting:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1031) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1047) [bundleFile:?]
at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:314) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) [bundleFile:1.0.9]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) [bundleFile:1.0.9]
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) [bundleFile:1.0.9]
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) [bundleFile:1.0.9]
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) [bundleFile:1.0.9]
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) [bundleFile:1.0.9]
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:267) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:216) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:301) [bundleFile:1.0.9]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doPost(AbstractHTTPServlet.java:220) [bundleFile:1.0.9]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [bundleFile:3.1.0]
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:276) [bundleFile:1.0.9]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
Caused by: java.lang.IllegalStateException: Cannot parse holidays XML file.
at de.jollyday.util.XMLUtil.unmarshallConfiguration(XMLUtil.java:75) ~[?:?]
at de.jollyday.datasource.impl.XmlFileDataSource.getConfiguration(XmlFileDataSource.java:41) ~[?:?]
... 100 more
Caused by: javax.xml.bind.UnmarshalException
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.createUnmarshalException(AbstractUnmarshallerImpl.java:310) ~[jakarta.xml.bind-api-2.3.2.jar:2.3.2]
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.createUnmarshalException(UnmarshallerImpl.java:548) ~[jaxb-runtime-2.3.2.jar:2.3.2]
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:234) ~[jaxb-runtime-2.3.2.jar:2.3.2]
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:199) ~[jaxb-runtime-2.3.2.jar:2.3.2]
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:140) ~[jakarta.xml.bind-api-2.3.2.jar:2.3.2]
at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:179) ~[jakarta.xml.bind-api-2.3.2.jar:2.3.2]
at de.jollyday.util.XMLUtil.unmarshallConfiguration(XMLUtil.java:72) ~[?:?]
... 100 more
Caused by: org.xml.sax.SAXParseException: Content ist nicht zulässig in Prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:204) ~[?:?]
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:178) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1471) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:978) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:605) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112) ~[?:?]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:534) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:888) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:824) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141) ~[?:?]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1216) ~[?:?]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:635) ~[?:?]
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:228) ~[jaxb-runtime-2.3.2.jar:2.3.2]
... 100 more
19:37:19.800 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.NumberFormatException: For input string: "o Preset"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:652) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:770) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.InputWithPresetControlXML.convertToPresetNumber(InputWithPresetControlXML.java:157) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.InputWithPresetControlXML.update(InputWithPresetControlXML.java:123) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.handler.YamahaZoneThingHandler.lambda$2(YamahaZoneThingHandler.java:725) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
