Design Pattern: Motion Sensor Timer
Some ideas:
If you use a lambda you can avoid duplicating the same code for each Sonos (if I understand your comment correctly).
If you use a Map you can drastically reduce the code in your rule. You can populate it using a HashMap but I prefer to use the MAP transform:
sonos.map
0=P4 Radio Norge
1=Korean Pop
2=Liberdade
3=Jazz
4=P5
5=Radio Sørlandet
6=Nrk MP3
7=BuddaBar
8=Something
9=Something else
rule "Sonos Bad1"
    Item Bad1VDSonos received update ON
    if(Bad1VDSonosOverride.state == OFF && Bad1_Sonos_State.state != "PLAYING"){
        Bad1_Sonos_Volume.sendCommand(Bad1VDSonosVolume.state as Number)
        Thread::sleep(100)
        Bad1_Sonos_PlayPlaylist.sendCommand(transform("MAP", sonos.map, Bad1SonosSelector.state.toString))
rule"Sonos OFF"
    Item Bad1VDSonos received update OFF
    if (Bad1_Sonos_State.state!="STOPPED"){
        Bad1_Sonos_Stop.sendCommand(ON)
With this approach not only is your Rule shorter, you can add and remove channels by simply editing the map file and you don’t have to touch your Rules. Note, it is better to call the method on the Item than to call the sendCommand Actions.
