Different bound and virtual trigger items: darkness, manual, gate contacts
2 proxy items:
fromFrontgate: handles frontgate and entry when front gate opens in darkness
fromCarport: handles carport and entry when carport gate opens in darkness
I currently have a wild combination of the virtual and proxy approach, which finally works somehow but the code is ugly and it takes me every time half an hour to re-understand it.
I would create a Group for each trigger and send command to the group. Items can be members of multiple groups and a command sent to a group gets forwarded to all itâs members.
You run into trouble when you start to need scenes (e.g you have a mix of dimmers, switches and color and each needs a custom value) in which case you need to use proxy items and rules.
Tried that but that led to the following conflict:
Lets say we have two groups A and B. Members of A are x and y, member of B are y and z.
Assume both groups are ON. Then the timer for group A expires, the timer for group B has still some time left. Switching off group A would switch off y which is not intended in this situation. As far as I concern there is no possibility to define an XOR
Group which would solve this situation.
Of course the logic will be a bit more complex because you donât need to send off if the light is already off and you only want to exclude B members sometimes, but this should address the problem somewhat.
Smart. There is so much you can do with the rules DSL and so little documentation. Even the Xtend / Xtext docs I found only cover the definition and implementation of a DSL, not its usage - do you have some hints where to look on the usage of an already defined DSL ?
How do I create the proxy switch to begin with? I have a zigbee switch that is reporting exactly opposite itâs setting (saying off when on and vice versa) and want to make a proxy switch to reverse it but unsure how to do so. I follow the logic of the rule and can see how to modify but donât know how to make the unbound switch in the first place.
Simpy create it, either through an *.items file or through Paper UI. Donât use curly brackets in the items definition (in items file the channel link), donât link the item to a channel.
rule "opposite switch"
Item myZigbeeSwitch changed
myProxySwitch.postUpdate(if(myZigbeeSwitch.state != ON) ON else OFF)
*.rules (complete):
switch (myZigbeeSwitch.state) {
case ON : OFF
case OFF : ON
default : NULL
*.rules (easy to read):
var mySwitch
case ON : mySwitch = OFF
case OFF : mySwitch = ON
default : mySwitch = NULL
myProxySwitch.postUpdate(mySwitch)
Apologies if this isnât quite the correct place to post but Iâm after some thoughts on the flow of my DPâŠ
Iâve got a few proxy and unbound items working fine:
vPresence ON / OFF - Someone is home or not
vEndOfDay - Essentially a ON / OFF to determine if we are in bed or not
Now vEndofDay can be triggered to ON / OFF by either an Alexa command, (good night or good morning) or by CRON rules at 00:30 and 6:00, (in case we forget to use the Alexa command).
No problems there, I have a rule that triggers on vEndofDay state changing and via an easy âifâ, ON runs my nighttime routine, (ie cameras on, tv off, lights to nightlight etc) and OFF turns it OFF, again no problems.
However, I only want this routine to trigger when vPresence = ON as I have another routine working when Iâm away to make the house act like someone is there and I donât want both rules to interfere with each other.
So, the DP questionâŠ
Should I have the original rules trigger and run based on one sole thing, ie cron or alexa command and then update the DP proxy item, vEndOfDay.
Then the larger rule âwhen Item vEndOfDay changedâ I incorporate an âif vPresence = ONâ to make it workâŠ
or
Should I only make the original rules update based on cron and vPresence state and then the DP Proxy Item will only update once all conditions are met?
My thought is that a proxy item should only really update based on one trigger and then it has far more options to control within the next rule, or should a DP Proxy item reall yonly be updated after all the multi if cases are met?
What is best depends on what you are using these Items to do. In particular, what Rules or other behaviors occur when the Item changes state? When do you want those things to occur? What else is happening at the same time that might cause interference?
These are questions you need to ask yourself and then code when the proxy Item getâs updated to meet your needs. There is no one correct approach.
Well, since this is a design pattern about Proxy Items and Udo says you can create it through *.items file I would have thought it was obvious that we are talking about Items.
If you donât have an Items entry along the left hand side in PaperUI, that means you have Simple Mode turned ON. You have to turn it OFF (Configuration > Settings) to see the Items option.
I have been struggling with getting my lights to work correctly, I am sure I must be using some kind of proxy item to get the result I am looking for.
The problem I have is my lights binding has the ON/OFF on a switch and the Brightness on a Number. so the two Items i have are
Switch Office_Power
Number Office_Brightness
The âOffice_Brightnessâ goes from value 1 to 100
I would really like to have a slider on my sitemap that goes from 0 to 100 where 0 turns the light off.
How do I go about combining the two items into one?
Did you already try to link both channels to one dimmer item?
To use two items and a proxy:
Switch Office_Power
Dimmer Office_Proxy "Office Light [%d %%]"
rule "office dimmer in"
Item Office_Power changed or
Item Office_Brightness changed
if(triggeringItem.name == "Office_Power") {
if(triggeringItem.state == OFF)
Office_Proxy.postUpdate(OFF)
} else {
if(triggeringItem.state instanceof Number)
Office_Proxy.postUpdate(triggeringItem.state as Number)
rule "office dimmer out"
Item Office_Proxy received command
switch (receivedCommand) {
case ON : {
if(Office_Power.state != ON) Office_Power.sendCommand(ON)
Office_Brightness.sendCommand(100)
case OFF : {
if(Office_Power.state != OFF) Office_Power.sendCommand(OFF)
default : {
if(receivedCommand == 0)
else {
Office_Brightness.sendCommand(receivedCommand)
Maybe itâs sufficient to sendCommand the Number to switch ON, maybe itâs sufficient to sendCommand ON to switch to 100% (this is dependent on your dimmer)
Thank you for taking the time to help me out. This is one of the last hurdles to overcome to make my system complete.
You have pointed me in the right direction, I have it now working, Modified the code a bit to make it work.
Maybe I am doing something not correctly but it works for now.
The rule I am using now is
Office_Proxy.postUpdate(0)
else if (triggeringItem.name == "Office_Power") {
if(triggeringItem.state == ON)
else {
default : {
if(receivedCommand > 0)
Hope I am now doing it correctly the log shows the following
2019-10-14 16:21:14.015 [ome.event.ItemCommandEvent] - Item 'Office_Brightness' received command 18
2019-10-14 16:21:14.018 [nt.ItemStatePredictedEvent] - Office_Brightness predicted to become 18
2019-10-14 16:21:14.038 [vent.ItemStateChangedEvent] - Office_Brightness changed from 39 to 18
2019-10-14 16:21:17.959 [ome.event.ItemCommandEvent] - Item 'Office_Brightness' received command 97
2019-10-14 16:21:17.964 [nt.ItemStatePredictedEvent] - Office_Brightness predicted to become 97
2019-10-14 16:21:18.009 [vent.ItemStateChangedEvent] - Office_Brightness changed from 18 to 97
else if (triggeringItem.name == "Office_Power") { //<--- this part is identical to the first if()
if(triggeringItem.state == ON) // <--- if state is ON it's never a
Office_Proxy.postUpdate(triggeringItem.state as Number) // <--- Number !
else {
This one will take care of the case âLight is switched on, but brightness did not changeâ:
else // command is ON or OFF, no other option!
Office_Proxy.postUpdate(Office_Brightness.state as Number)
} else {
default : {
If there is no option other than default, why switching at all (and for the record: even if you do not send a command ON or OFF through the UI, itâs possible to use Office_Proxy.sendCommand(ON) or OFF from a rule.
If you donât want to use this option, the second rule is even shorter:
if(receivedCommand instanceof Number) {
if(receivedCommand > 0) {
