Hi, the following code should be working now, but as I moved away from the enocean rocker switches towards Homematic switches, I am no longer able to test it:
import java.util.Map
import org.eclipse.smarthome.model.script.ScriptServiceUtil
import org.eclipse.smarthome.core.thing.events.ChannelTriggeredEvent
val Map<String, Timer> Counters = newHashMap
val Map<String, Timer> Timers = newHashMap
val Map<String, DateTime> Timestamps = newHashMap
val incrementCounter = [ String id, boolean resetCounter, Map<String, Timer> Counters |
val item = ScriptServiceUtil.getItemRegistry.getItem(id + "Count")
val count = (item.state as Number).intValue + 1
postUpdate(id + "Count", String::format("%d", count))
if (resetCounter) {
// Deactivate the timer (if running)
Counters.get(id)?.cancel()
Counters.remove(id)
val offset = now.plusSeconds(10)
Counters.put(id, createTimer(offset, [|
postUpdate(id + "Count", "0")
val simpleSwitch = [ ChannelTriggeredEvent receivedEvent, String id, boolean resetCounter, Map<String, Timer> Counters, Map<String, Timer> Timers, Map<String, DateTime> Timestamps |
if (receivedEvent.event.endsWith("PRESSED")) {
incrementCounter.apply(id, resetCounter, Counters)
sendCommand(id, "ON")
if (receivedEvent.event.endsWith("RELEASED")) {
sendCommand(id, "OFF")
val doubleSwitch = [ ChannelTriggeredEvent receivedEvent, String id, boolean resetCounter, Map<String, Timer> Counters, Map<String, Timer> Timers, Map<String, DateTime> Timestamps |
Timestamps.put(id, now)
// Get timestamp of switch pressed down
var pressed = Timestamps.get(id)
Timestamps.remove(id)
// Handle short or long press
val offset = pressed?.plusMillis(700)
if (now.isBefore(offset)) {
sendCommand(id + "ShortPress", "ON")
sendCommand(id + "ShortPress", "OFF")
} else {
sendCommand(id + "LongPress", "ON")
sendCommand(id + "LongPress", "OFF")
val dimmerSwitch = [ ChannelTriggeredEvent receivedEvent, String id, boolean resetCounter, Map<String, Timer> Counters, Map<String, Timer> Timers, Map<String, DateTime> Timestamps |
// Start timer if switch is held down
val offset = now.plusMillis(700)
Timers.put(id, createTimer(offset, [|
// Handle long press
// Reschedule timer for this switch, but max. 10 times
if (now.isBefore(Timestamps.get(id)?.plusSeconds(7))) {
val newoffset = now.plusMillis(700)
Timers.get(id)?.reschedule(newoffset)
Timers.get(id)?.cancel()
Timers.remove(id)
rule "Configuration Button 1"
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchA" triggered DIR1_PRESSED or
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchA" triggered DIR1_RELEASED
simpleSwitch.apply(receivedEvent, "Button_1", false, Counters, Timers, Timestamps)
rule "Configuration Button 2"
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchB" triggered DIR1_PRESSED or
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchB" triggered DIR1_RELEASED
doubleSwitch.apply(receivedEvent, "Button_2", false, Counters, Timers, Timestamps)
rule "Configuration Button 3"
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchA" triggered DIR2_PRESSED or
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchA" triggered DIR2_RELEASED
dimmerSwitch.apply(receivedEvent, "Button_3", false, Counters, Timers, Timestamps)
rule "Configuration of Button 4"
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchB" triggered DIR2_PRESSED or
Channel "enocean:rockerSwitch:FT1I6L57:0035FA61:rockerswitchB" triggered DIR2_RELEASED
dimmerSwitch.apply(receivedEvent, "Button_4", true, Counters, Timers, Timestamps)
Please note that I remove the “maxCount” variable due to a limitation of the rule dsl that allows a max. of 6 parameters for lambdas. The counter will increment to infinity until it will be reset (if resetCounter boolean was set to true). Otherwise, I suggest that the rule that handles the profiles and reads the Counter Item should reset it, if it exceeds the last known profile id.
The latency is quite ok. For sure you have a delay for the long press which is a natural thing, as the script needs to wait for the given time until it can detect the long press. I didnt feel like it was a negativ effect.
So give it a try and let us know how it works
Best Bechte
