[Deprecated] Design Pattern: Time Of Day
Hi Allen,
if I understand you right, you’re using only one Thing (“local” or “home”). Do you ? If so, you have to create another one (“minus90” or whatever name you want to have) with the offset-time. You can do this with Paper UI too, I think. Or just creating a .things File for the minus90-Thing as shown in my example above. I think this should work too.
Try it. :wink: When you have done it, you should see a log-message like the below one:
The result should look like here:
But be aware, if you make changes in your .items-file, your channel linked items values will be NULL. So for the “normal” ones (thats the items which are channel-linked to “local” or “home”) will be updated after the interval-time, but not the item linked with the “minus90”-Channel. This one is only updated after a Start of OH2 or after the midnight-rescheduling. Another way in this case could be to restart the Binding on the Console.Use
bundle:list | grep -i astro
to find out the ID of your astro-binding
and then use (but with your ID)
bundle:restart 212
to restart the Binding/Bundle
EDIT:
For testing purposes you can set a value to a specific item in the console too. Use this command
smarthome:send vEvening_Time 18:32
Yep, that was it: I was able to add another Astro binding in PaperUI and for the Sunset Start event put an offset of -90. I got the ID of the binding (like I did for my other ones) and put that into my “vEvening_Time” channel id and my “Afternoon” value is now showing 90 minutes before the real sunset start.
Thanks! I feel d-u-m-b, but unfortunately it is not the only time I will probably feel that way :frowning:
Fortunately, I believe I know enough now to be able to set some rules based on the TOD (like turning on my lights, etc.), and build form there.
Thanks again!
I’ve made some changes to the original rule. All seems to work as expected until my last case statement for ‘BED’. Instead, I recieve [INFO ] [e.smarthome.model.script.Time Of Day] - Calculated time of day is UNKNOWN
My rule is as follows:
val todLog = "Time Of Day"
rule "Calculate time of day state"
  System started or // Run at system start in case the time changed when OH was offline
  Channel 'astro:sun:home:rise#event'    triggered START or
  Channel 'astro:sun:home:set#event'     triggered START or
  Time cron "0 1 0 * * ? *" or // One minute after midnight so give Astro time to calculate the new day's times
  Time cron "0 0 12 * * ? *" or
  Time cron "0 0 17 * * ? *" or
  Time cron "0 0 22 * * ? *" or
  Time cron "0 0 23 * * ? *"
  logInfo(todLog, "Calculating time of day...")
  // Calculate the times for the static tods and populate the associated Items
  // Update when changing static times
  // Jump to tomorrow and subtract to avoid problems at the change over to/from DST
  val midday_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(12)
  vMidday_Time.postUpdate(midday_start.toString)
  val earlyEvening_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(7)
  vEarlyEvening_Time.postUpdate(earlyEvening_start.toString)
  val night_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(2)
  vNight_Time.postUpdate(night_start.toString)
  val bed_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(1)
  vBed_Time.postUpdate(bed_start.toString)
  // Convert the Astro Items to Joda DateTime
  val sunrise_start = new DateTime(vSunrise_Time.state.toString)
  val lateEvening_start = new DateTime(vSunset_Time.state.toString)
  // Calculate the current time of day
  var curr = "UNKNOWN"
  switch now {
    case now.isAfter(sunrise_start)       && now.isBefore(midday_start):        curr = "MORNING"
  	case now.isAfter(midday_start)        && now.isBefore(earlyEvening_start):  curr = "AFTERNOON"
    case now.isAfter(earlyEvening_start)  && now.isBefore(lateEvening_start):   curr = "EARLY EVENING"
  	case now.isAfter(lateEvening_start)   && now.isBefore(night_start):         curr = "LATE EVENING"
  	case now.isAfter(night_start)         && now.isBefore(bed_start):           curr = "NIGHT"
  	case now.isAfter(bed_start)           && now.isBefore(sunrise_start):       curr = "BED"
  // Publish the current state
  logInfo(todLog, "Calculated time of day is " + curr)
  vTimeOfDay.sendCommand(curr)
Any help would be most appreciated. As i say, all my other time of days work correctly :frowning:
Many thanks,
Jeevs
Consider when these values get calculated.
bed_start get’s calculated for today. sunrise_start get’s calculated for today. So
bed_start      = 2019-04-18 23:00
sunrise_start  = 2019-04-18 06:20
Your last case can never be true between 2019-04-18 23:00 and 2019-04-19 00:00 (or whenever Astro generates the sunrise start time for the new day).
The switch statement works in the OP because bed_time is 2019-04-19 00:00 so there isn’t that gap between when bedtime starts and Astro recalculates the sunrise time for the new day.
This is why it is particularly important to not just copy this DP but to really understand how this DP works in order to use it successfully.
To do this successfully, you need to have a separate case statement to cover the time between bed_start and midnight. Then you need another one to cover the time between midnight and sunrise.
rule "TimeOfDayRule"
    System started or
    Time cron "0 0 * ? * * *"
    if (now.getHourOfDay() >= 00 && now.getHourOfDay() < 06){
		myTimeOfDayMode.postUpdate("Night")
	if (now.getHourOfDay() >= 06 && now.getHourOfDay() < 09){
		myTimeOfDayMode.postUpdate("Morning")
	if (now.getHourOfDay() >= 09 && now.getHourOfDay() < 16){
		myTimeOfDayMode.postUpdate("Daytime")
	if (now.getHourOfDay() >= 16 && now.getHourOfDay() < 23){
		myTimeOfDayMode.postUpdate("Evening")
	if (now.getHourOfDay() >= 23 && now.getHourOfDay() < 24){
Thank you both very much! It’s now clear how this works. So, thank you both for the clear responses.
I’ve made changes to my rule, so fingers crossed it should work as expected.
Many thanks :wink:
Hi all,
So the more I’m getting into OH the more I find I’m using this pattern to run other rules depending on the time of day, so first off thanks for creating it!
I have relatively the same time sections, with
BED being midnight to 6am
And
DAWN being 6am to sunrise
Now this works fine for some of the year, when sunrise is after 6am, and I’ve coded it this way so that my lights slowly go off at dawn, and any light on motion doesn’t go on after sunrise etc.
However, for me and I’m guessing many others, sunrise is before 6am for at least half of the year so DAWN as a time never occurs, it goes straight to DAY, missing out some of my hard coded rules where vTimeOfDay == DAWN.
How do others work around this and is there a way to code in an if sunrise > 6am then do something else sunrise < 6am
Or, should we not really be using hard coded times in this instance?
Thoughts?
Simply use ASTRO to get the locationsspecific times for sunrise, dawn etc. This way the modes are independent of season and location and always correct
Thanks, so that’s 1 for don’t hard code any times in there, use the astro binding…
How about when dawn and sunrise are much earlier in the morning that when people get up, for example, if I turned off my cameras as dawn or sunset right now they would be off at 4:35 or 5:35, we don’t get up until nearer 7 usually.
What @rlkoshak made is a DP to learn all of us how the handling with Time Of Day could be done. It’s not a solution. One can change it as one need.
If you want to handle your specific purposes you can use the “Astro-Thing(s)” as you want, even with Offsets and/or “earliest/latest”-restriction as shown in my example above
As you see you can make as much Astro-Things as you need for your own purposes and use it in your Rules as you want and the DP can help you to realise.
Cheers
Peter
Yes, I wasn’t for a second saying the original rule wasn’t right, far from it, I’ve used it well for many things.
I was just after a few ideas on different ways to tweak it to avoid the sunrise / 6am issue I mentioned.
For me this is the desired behavior. But if you don’t want this to occur, set the dawn start to sunrise with an offset in Astro instead of hard coding it to 6am.
Of course, a long as you can have some event that yesterday the rule at the right time. Then you just have
if(dawn_start.isAfter(day_start))
    // Do something else
Thanks, I could offset but as sunset and dawn move, it will always be out, just less and less as the year goes on, which is why I hard coded the 6am, but now I’m finding / realising why you wouldn’t do this.
To be honest, I might just have to hard code this rule I’ve got, rather than shoe horn it into the time of day rule I have
With the ‘isafter’ part, that’s exactly what I was after. I know OH uses Xtend but is there a resource anywhere with just a list of the coding options? I’ve trawled the web but am yet to find a site / reference page with all the options on, it would really speed up my knowledge / development if there was something I could refer to???
The answer is yes. The problem is there are four of them. There is the Xtend reference docs (linked to from the Rules page), the Java API, the OH API, and in this case the Joda API.
There are literally hundreds and hundreds of pages of this stuff that we simply cannot reproduce/duplicate in the OH docs.
If you are dealing with a DateTime look at the Joda javadocs. If you are dealing with something OH specific, look at the ESH javadocs (I don’t think these have moved yet). If you are dealing with standard Java stuff look at the Java 8 javadocs.
But what you really should do is use VSCode with the oh extension which will tell you all the valid ways to compete a line as you type. For example, if you type “now.” a dialog will pop up and tell you all the methods like “isAfter” that are available.
Just aside:
Please open an issue if you found something that hasn’t been ported yet.
Thanks, going to download VSCode editor and take a look, that sounds an awful lot better than my current editor!
So I had a fiddle with the isBefore idea, here’s the code, basically morning start is hard coded 6am and day start is sunrise. so if 6am is before sunrise do one switch(now) otherwise do the other.
Is there anything to add / modify to make it tidier, (still trying to learn best practise)
  if(morning_start.isBefore(day_start))
    switch now {
  	  case now.isAfter(morning_start)   && now.isBefore(day_start):       curr = "DAWN"
  	  case now.isAfter(day_start)       && now.isBefore(afternoon_start): curr = "DAY"
  	  case now.isAfter(afternoon_start) && now.isBefore(evening_start):   curr = "TWILIGHT"
  	  case now.isAfter(evening_start)   && now.isBefore(night_start):     curr = "EVENING"
          case now.isAfter(night_start):                                      curr = "NIGHT"
  	  case now.isAfter(bed_start)       && now.isBefore(morning_start):   curr = "BED"
    else
    switch now {
  	  case now.isAfter(day_start)       && now.isBefore(morning_start):   curr = "DAWN"
  	  case now.isAfter(morning_start)   && now.isBefore(afternoon_start): curr = "DAY"
  	  case now.isAfter(bed_start)       && now.isBefore(day_start):       curr = "BED"
this is a pretty good start
xtend documentation
https://eclipse.org/xtend/documentation/203_xtend_expressions.html
The major point here would be the indentation, you are using (if I count correctly) 3 indentation styles combined in this piece of code, and something funny was going on with the spacing you were using. I would write it as below. And you were missing a closing accolade, which becomes obvious a lot quicker if you use consistent indentation
    if(morning_start.isBefore(day_start)) {
        switch now {
    } else {
        switch now {
Thanks, the final closing accolade is on my code, must have missed it off the copy and paste but I certainly take your point with the indentation. I’m always worried if the syntax gets picky when accolades aren’t on the some line, next line, or even if extra blank lines affect it.
I’m an old school html / asp / vb script coder and love nothing more than retentively indenting codes but when I’m first learning new code I tend to copy and paste from other code, (ie this example), but not change it for fear of something going wrong…
