Design Pattern: Time of Last Update
You have to go about it the other way.
Create your free-standing DateTime Item first, then link that to the channel.
Thank you :slight_smile: - this worked.
My motion sensor reports to a contact item. Can I have the last OPEN state with this design pattern? I guess I cannot use timestamp-update, as the motion sensor sends it’s state in regular intervals, even without change.
I am trying to use this design pattern for my sensor battery similar to OP. The channel is linked to the item (Battery_LastUpdate) as shown below,
You would notice that the item shows an ‘Err’ above and also does the same in Model. I dont understand this since in ‘Items’ it shows the correct date,
The item is defined like so,
Maybe this may help?
Thanks, that did the trick.
It is much easier with picture examples that you can adapt.
Glad it worked for you. Thanks for the like!
4 posts were split to a new topic: Time of last update = 1970
