Hi.
Why is this not working?
I want it to return true if i push the button 2 times within within 30 sec.
My items files have this
String KnapA “KnapA [%s]” (Kontakter) {channel=“zwave:device:a3ceef84:node2:scene_number”}
And my rules file have this.
if (KnapA.lastUpdate.isAfter(now.minusSeconds(30)) {
logInfo(“Test”, “Nubnub”)
I have persist active
As the rule would trigger through KnapA, I think, KnapA.lastUpdate will be always ~ now() You will have to use another counter:
var Timer tKnapA = null
rule "detect double press"
Item KnapA received update
if (tKnapA != null) {
logInfo("Test","Nubnub")
tKnapA.cancel
tKnapA = null
else
tKnapA = createTimer(now.plusSeconds(30),[|
logInfo("Test","Nub")
Hi. Thanks.
It looks like it fails at
Timer tKnapA = null
Configuration model ‘huset.rules’ is either empty or cannot be parsed correctly!
Is there any place where i can find all this advanced commands like now.plusSeconds(30)?
Argh… sorry, should be
(will correct this in my prior posting)
