I’ve picked my OH deployment back up after moving house, I am playing around with my kegbot installation to play TTS over alexa when I pour a beer.
I am picking up the volume of keg remaining into an item. I basically want to play a TTS when the volume changes.
From what I understand I need to setup persistance and use previous state. The item is a number but I am having trouble with persistance and how to get the number value and previous number value. One of them is NULL.
Not sure which code to paste or how to troubleshoot!
rule “Tap 3 pour”
Item tap3_vol_remaining received update
if (tap3_vol_remaining.state.toString != tap3_vol_remaining.previousState.state.toString) {
Garage_Speak.sendCommand('Enjoy '+ tap3_name.state)
Did you install and setup a persistence service? I would use rrd4j.
I would cast the state to a number type.
For debugging insert logInfo lines, the will show in the logs.
Example logInfo("MyRule","Value of tap3_vol_remaining: {}", tap3_vol_remaining.state)
No, you don’t need persistence Instead you need another trigger:
rule "Tap 3 pour"
Item tap3_vol_remaining changed
if (previousState !== null) {
When using changed as trigger, there is a implicit variable previousStatewithout an installed persistence service. Because the first status (when openHAB ist starting up) is null, we have to prevent a false positive
Another false positive will be if the volume changes in the wrong direction, you could prevent this by comparison…
rule "Tap 3 pour"
if ((previousState as Number) > (tap3_vol_remaining.state as Number)) {
However, this will only work if it’s a number item.
As the Item is named tap3… are there other tapX which shall also trigger a message?
Group gAllTapRemain
Group gAllTapName
Number tap1_vol_remaining "Tap1 [%d]" (gAllTapRemain) {...}
Number tap2_vol_remaining "Tap2 [%d]" (gAllTapRemain) {...}
Number tap3_vol_remaining "Tap3 [%d]" (gAllTapRemain) {...}
String tap1_name "Tap1 [%s]" (gAllTapName)
String tap2_name "Tap1 [%s]" (gAllTapName)
String tap3_name "Tap1 [%s]" (gAllTapName)
rule:
rule "Tap pour"
Member of gAllTapRemain changed // one Tap was changed
if(previousState === null) return; // startup, so stop rule
var String strTap = triggeringItem.name.split("_").get(0) // get Index
var iTapName = gAllTapName.members.filter[i | i.name.contains(strTap)].head // get Name as Item
if ((previousState as Number) > (triggeringItem.state as Number)) { // if level has fallen
Garage_Speak.sendCommand('Enjoy '+ iTapName.state) // say the Name...
As you can see, I changed the rule slightly, the rule now will return if changing from null.
