@chris @petr This is a continuation of posting https://groups.google.com/forum/#!msg/openhab/Lg_k_T9S9cg/OA91MC5285QJ
which focuses on reading out gyroscopic data from a sensor, which is reported as tamper (command=sensor_alarm).
The Fibaro product PDF (http://www.fibaro.com/manuals/en/Motion-Sensor/Motion-Sensor_EN_5.3.14.pdf), page 1, upper right corner, shows a nice seismic graph that is probably plotted inside Home Center.
I want to have the same in OpenHAB.
My motion sensors are configured in habmin with regards to parameters 20 - 24 to report frequently (every 4 sec), sensitivity 1g, and 24 = 3, i. e. number of vibrations. Data is synced to the sensor (no longer yellow).
I tried these item definitions for my 3 sensors:
Number Fibaro_1_Tamper "Manipulation @EG Treppenhaus [%f Vibrationen]" (gEG, gVibration) {zwave="2:command=sensor_alarm"}
Number Fibaro_2_Tamper "Manipulation @OG2 Flur [%f Vibrationen]" (gOG2, gVibration) {zwave="4:command=sensor_alarm"}
Number Fibaro_3_Tamper "Manipulation @EG Wohnzimmer [%f Vibrationen]" (gEG, gVibration) {zwave="21:command=sensor_alarm"}
But nothing shows up when I display the group gVibration in the sitemap.
Any suggestion what data type I should use? For tamper I was expecting Contact or Switch (Boolean), but “number of vibrations” sound more like an integer / Number. Also, for orientation in space, I would expect three coordinates – so probably a String?
Regarding the sensor, this must be a gyro, no magnetometer, so it only gives acceleration, but not (as quoted) also orientation in space?
