Openhab2 2.0.0. snapshot
I have a devolo indoor siren, which is correct detected. i can switch i on / an of , but it is always silent.
detected type
from the log
NODE 2: Device discovery resolved to thingType zwave:devolo_phpse02_00_000
NODE 2: Node advancer: DYNAMIC_VALUES - checking ZWAVE_PLUS_INFO
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking ALARM
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - found ALARM
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Found 1 instances of ALARM
2016-11-20 10:52:13.315 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 2: Creating new message for application command NOTIFICATION_GET V4
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer - queued packet. Queue length is 1
2016-11-20 10:52:13.315 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Found 1 instances of SWITCH_BINARY
2016-11-20 10:52:13.315 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 2: Creating new message for application command SWITCH_BINARY_GET
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking FIRMWARE_UPDATE_MD
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking POWERLEVEL
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - found POWERLEVEL
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Found 1 instances of POWERLEVEL
2016-11-20 10:52:13.315 [DEBUG] [andclass.ZWavePowerLevelCommandClass] - NODE 2: Creating new message for application command POWERLEVEL_GET
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking SENSOR_BINARY
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - found SENSOR_BINARY
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Found 1 instances of SENSOR_BINARY
2016-11-20 10:52:13.315 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 2: Creating new message for application command SENSOR_BINARY_GET for TAMPER
2016-11-20 10:52:13.315 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 2: Creating new message for application command SENSOR_BINARY_GET for GENERAL
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION_GROUP_INFO
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - checking BASIC
2016-11-20 10:52:13.315 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: DYNAMIC_VALUES - queued 6 frames
2016-11-20 10:52:13.315 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Response processed after 25ms/99ms.
2016-11-20 10:52:13.315 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
Received HTTP POST request at 'items/alarmtonon' with value 'OFF'.
2016-11-20 11:02:43.417 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating command 'OFF' for item 'alarmtonon' to handler for channel 'zwave:device:2fb2f81a:node2:switch_binary'
2016-11-20 11:02:43.417 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:2fb2f81a:node2:switch_binary --> OFF
2016-11-20 11:02:43.417 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 2: Creating new message for application command SWITCH_BINARY_SET
2016-11-20 11:02:43.417 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2016-11-20 11:02:43.417 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-11-20 11:02:43.418 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 02 03 25 01 00 25 13 F5
2016-11-20 11:02:43.418 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 25 01 00 25 13 F5
2016-11-20 11:02:43.418 [DEBUG] [ome.core.thing.internal.ThingManager] - Delegating update 'OFF' for item 'alarmtonon' to handler for channel 'zwave:device:2fb2f81a:node2:switch_binary'
2016-11-20 11:02:43.425 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-11-20 11:02:43.426 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
All other channels doing nothing
any ideas ?
Thanks in advance
Alexander
