Develop Binding with OAuth1
I’m currently developing a binding that interacts with an external REST API.The only authentication option for this API is OAuth1. jetty-client does not seem to support OAuth1. My plan is to use scribejava-core instead. Is there any recommended OAuth1-capable HTTP client already used within OpenHAB?
Both OAuth 1 and OAuth 2 rely on custom Authorization scheme (next to basic/digest). It means that any HTTP client library which allows you to pass value for authorization header should be sufficient.
What you need is a OAuth 1.0 client library which can handle redirects and whole dance related to access delegation. You can use ie. https://github.com/googleapis/google-oauth-java-client which handles both OAuth 2 and 1. It is shipped with OSGi metadata (not sure about its quality) thus should be sufficient to go.
Best,
Łukasz
