Is it possiable to create binding jar file without Eclipse or any other fancy ide?
I know what I wont and it took me less then 10 minute to implement this in java with simple ide but after 2 days of trying to setup the Eclipse ide with openhab environment I give up
Yes it’s possible and preferred to build you binding jar with maven. See here for the command line options you can use related to openHAB binding building (step 3): Developer Guide | openHAB
Related to Eclipse installation. I assume you did follow the instructions on the openHAB documentation related to Eclipse IDE installation? Eclipse IDE | openHAB If so what problems did you encounter?
I follow the doc step by step but I got some errors like unable to resolve or file not found
I try the installation again
Is there a sample or empty project beside the script that create one?
Your binding is probably missing from the bundles/pom.xml For some reason when generating with the skeleton it doesn’t update all files. What OS are your running on?
